Wiring diagram for a 94 Civic
Old Dec 15, 2002 | 11:21 AM
csprague's Avatar
Default Wiring diagram for a 94 Civic
I'm trying to install a keyless entry (Crimestopper CS-845). It's a 94 Civic LX 4dr. Thanks
Old Dec 15, 2002 | 02:24 PM
TurboBumblBee's Avatar
Default Re: Wiring diagram for a 94 Civic (mankala007)
Heh , noob j/k
Try calling crutchfield. THey have full technicle support on everything they sell. Where did you get the alarm? I think crutchfield sells that one.
OR you just have access to DEI's (dei makes about every alarm out there so they know there ****, incase you didnt know who DEI was) technical website and be a good person and get the correct info for a fellow honda-tech member and quite wasting board space w/ senseless comments like you just did NOOB!!
12volts white + steering column
Starter black/white + steering column
Ignition black/yellow + steering column
Power Lock green/white - 2pin plg blue-taped to
Power Unlock green/red - blue plg behind f-box
Lock Motor none non none
Unlock Motor none non none
Disarm Defeat none non none
Parking Lights+ red/black at fuse box or d.k.p
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger lt. green/red - driver kick panel
Dome Supervision none non none
Trunk/Hatch Pin grn/blk 2 sil.dot - blue conn. above fusbx
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock none non none
Tachometer blue AC 2-pin conn. near dist.
Horn Trigger blu/grn, blu/red - at steering column
[Modified by 95CivicEX, 6:25 PM 12/15/2002]
Old Dec 15, 2002 | 05:23 PM
csprague's Avatar
Default Re: Wiring diagram for a 94 Civic (95CivicEX)
Thanks a lot, 95CivicEX.
ProjectEJ2
Audio / Security / Video
Jul 31, 2007 08:40 AM
DB1_559
Jan 27, 2006 02:29 PM
94 civic all mtr
Oct 5, 2003 07:34 PM
ultraREY
Feb 12, 2003 12:03 AM
