what tire size for si wheels?
i'm not familiar with what all the numbers mean in tire sizes and was just wondering if this would work: i have si wheels (14 inch) on a crx - would Falken AZENIS Sport (RS) 195/60HR14 fit ok on the wheels and in the wheel wells? i ask because when i enter my vehicle on tirerack it recommends 185/60.
thanks
thanks
185/60/14 stock for us
195/60/14 for japan
both will fit
or you can find 195/55/14 which are harder to find and way more expensive...
195/60/14 for japan
both will fit
so what is the difference between the 185 and 195? what dimension is it?
i'm just trying to figure out what will change.
thanks for the replies
195 is 10mm wider than the 185
1st number- 185 = how wide the tread is in MM
2nd number- 60= % ratio of the with in the sidewall
3rd number- 14= how big the rim is...
ok cool. i found some at http://www.vulcantire.com/ for $46. anyone done business with these guys? i cant believe how cheap that is. now only if i didnt need snow tires...
thanks again
thanks again
Dainbramage
Jun 22, 2004 06:57 PM
