how to get rid of tint
Old Dec 15, 2002 | 08:43 AM
Ronin Integra8's Avatar
Default how to get rid of tint
i keep getting tickets for my tint being dark, so I'm gona take it off.
Can someone tell me how to take it off clean?
Old Dec 15, 2002 | 09:33 AM
Evil EG's Avatar
Default Re: how to get rid of tint (Ronin Integra8)
Some goo-gone, A razor blade and lots of time, and a hairdryer.
Old Dec 15, 2002 | 10:34 AM
Red!ine's Avatar
Default Re: how to get rid of tint (BVM)
Rip off the tint.. mix some water & dishwashing soup.. spray on the sticky icky.. let it sit for a minute.. scrape off with a razor blade. Not sure how to remove the rear window tint without damaging the defrosters though.
Old Dec 15, 2002 | 10:59 AM
tub_sephiroth's Avatar
Default Re: how to get rid of tint (kAoTiK)
All you need is a razor blade and some goo gone or rubbing alcohol. I prefer rubbing alcohol. Takes it right off. This is so easy. I don't know about the rear though. That has defroster so be careful.
Old Dec 15, 2002 | 11:22 AM
shamoo's Avatar
Will you make something up for me please?
That's exactly what I did. It's time consuming either way you do it. Rip off as much as you can so all that's left is that sticky residue. Spray that water/soap combo on and scrape it off.
Good luck.
I have no idea what to do with the rear. I know most tint places are able to remove it for you. Maybe ask them?
Old Dec 15, 2002 | 11:49 AM
threatcon13's Avatar
New User
Default Re: how to get rid of tint (shamoo)
take it to a tint shop. they took mine off for 10 bucks. the chemicals they used in the car..oh damn. i got dizzy just from standing outside the car. but it was only like a one minute job with the stuff they used.
Old Dec 15, 2002 | 01:26 PM
cheezthis's Avatar
Default Re: how to get rid of tint (ALLMOTORDC2)
I actually tried a different method a couple weeks ago removing mine.
I used a $20 garment/curtain steamer, it's about the size of an ice scraper. I just steamed the tint, and it pulled right off. There was some gluey residue left behind in a few spots, but I just used concentrated Windex and generic scotch pads....came right off.
...and I didn't lose a single defroster line.
Old Dec 15, 2002 | 05:51 PM
maggsgsr's Avatar
Default Re: how to get rid of tint (cheezthis)
get some window cleaner with amoia and a heat gun and it will come right off. I'm happy as hell I pulled my tint off and don't have to worry about getting pulled over for tint anymore,plus I think the car looks cleaner.
Old Dec 15, 2002 | 06:03 PM
Ragged91ZC's Avatar
Default Re: how to get rid of tint (maggsgsr)
i got pulled over and took off the front. the back should be legal so you could have the option of leaving it on. in NY only the front 2 have to be clear.
Old Dec 15, 2002 | 06:10 PM
Smoochy's Avatar
use something wider than a razor blade, i'm sure your local hardware store will have exactly what you need
Old Dec 15, 2002 | 06:31 PM
burk's Avatar
Default Re: how to get rid of tint (DankGSR)
dude, your in for a treat..... it ****** sucks.
Old Dec 16, 2002 | 01:55 AM
LOKTiN's Avatar
Default Re: how to get rid of tint (burk)
just slice the tint on the window...slash it across and start peeling...shouldn't be too hard and then for the residue, get some glass cleaner foam **** in a spray can and let it soak for about 30 seconds and scrape with the blade. Everything comes off in less than a minute. its so damn easy with just a exacto blade and some cleaner...good luck.
Old Dec 17, 2002 | 10:18 AM
migs's Avatar
Default Re: how to get rid of tint (LOKTiN)
I just pulled mine off the other weekend. It looks alot better and my rear defroster works.
Materials Needed (in my case):
Windex
A couple of blades
Rags
Steel Wool (fine grit), the middle grade
Procedures
I removed ALL my rear interior panels that would have been dripped on by WINDEX. I then used a blade to peel off a corner to start the tear. I tore off the tint. Sometimes, it left a glue film behind, sometimes it didnt. I sprayed the heck out of the window. Once it was doused, I immediately started to use a blade to take off the glue. Once you accumulate alot of glue, the glue looks like a BIG loogy.
After I took off the blue once, I re-doused the window with Windex again to make sure all glue was gone. Clean it off with windex some more.
For the back, use the same procedures except use the Steel Wool over the heater film. It will NOT damage as long as you apply Windex. Took only 2 hours for me.
Good luck
---migs
Old Dec 17, 2002 | 10:32 AM
freakin_eLRoD's Avatar
My buddy owns a local tint shop and what he does is he sprays windex and applies black trash bags to the tinted windows. Then he uses a heat gun on the outside of the window, or leaves it out in direct sun light for about an hour or two, and the tint falls right off leaving no residue behind.
[Modified by 96jdmcoupe, 7:33 PM 12/17/2002]
Old Dec 17, 2002 | 10:49 AM
mugenracer's Avatar
Default Re: how to get rid of tint (96jdmcoupe)
when i got my car the rear side windows had limo tint, i was getting a 70% tint all round and took the limo off before getting it done, i just used a hair dryer and blade, and then cleaned the residue off with windolene/windex, it came of very easy and didnt tear in bits as i was removing it!
WolfDragon
Apr 26, 2018 10:41 PM
Kyle700
15
Oct 10, 2014 07:02 PM
shivern
14
Oct 20, 2004 04:58 PM
1 point 6
Oct 20, 2003 09:00 AM
PnX-R
Feb 9, 2002 09:16 AM
