Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Anyone using FRONT lower tie bars?
Old Dec 15, 2002 | 08:15 AM
Joon525's Avatar
Default Anyone using FRONT lower tie bars?
Just wondering if anyone in here is using one. And if so do you think it helped any? Know of any downsides? I'm debating buying one.
(Yeah it looks like it's touching the header in this picture but it really isn't.)
Old Dec 15, 2002 | 08:23 AM
.RJ's Avatar
.RJ
Default Re: Anyone using FRONT lower tie bars? (Joon525)
if its connecting to the subframe i cant see it doing a whole lot for you.
Old Dec 15, 2002 | 08:38 AM
civicrr's Avatar
Default Re: Anyone using FRONT lower tie bars? (.RJ)
On my second one. The first was sacraficed to a berm when someone turned down on me. It saved my oil pan & header. They told me they didn't see after the race. I THINK it helps to stiffen the front. I will continue to run one because of the above.
Old Dec 15, 2002 | 02:32 PM
FourthGenHatch's Avatar
Default Re: Anyone using FRONT lower tie bars? (civicrr)
It helps the steering response a lot. I suppose it does help to protect things under the car.
Old Dec 15, 2002 | 02:41 PM
Johnny Tran's Avatar
your car is plastic.....anything would help.
Old Dec 15, 2002 | 02:42 PM
Tweakmeister's Avatar
Default Re: Anyone using FRONT lower tie bars? (FourthGenHatch)
i bought that same cusco one from Leo at Jspec.
cheap enough.....nice bar
Old Dec 15, 2002 | 03:11 PM
ruthless013's Avatar
Default Re: Anyone using FRONT lower tie bars? (Tweakmeister)
SCRAAAAAPE.
that would have to be a track only piece - i wouldn't get through a regular day with it on. i'd install it in my garage and it would get torn off before i got out of the complex.
looks cool though.
after giving it some more thought - yeah, it would still scrape.
[Modified by ruthless013, 4:14 PM 12/15/2002]
Old Dec 15, 2002 | 03:24 PM
.RJ's Avatar
.RJ
Default Re: Anyone using FRONT lower tie bars? (Johnny Tran)
The prelude is coming.....
Old Dec 15, 2002 | 04:05 PM
smokin rubber's Avatar
Default Re: Anyone using FRONT lower tie bars? (ruthless013)
SCRAAAAAPE.
looks cool though.
Unless your speedbumps run parallel to the curb, they should not be a problem, the bar is directly between the wheels.
Old Dec 15, 2002 | 07:38 PM
Default Re: Anyone using FRONT lower tie bars? (smokin rubber)
My bar has never scraped anything.
Old Dec 15, 2002 | 08:45 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
I noticed a small difference with mine, less pushing. Totally mutilates road kill when i drive over it though..
Old Dec 16, 2002 | 05:31 AM
Default Re: Anyone using FRONT lower tie bars? (Rguy)
*mental note *
this is reason enough for me to blow rent money on one...
or mig weld some "prongs" onto a homemade version.
Old Dec 16, 2002 | 06:38 AM
PseudoRealityX's Avatar
I did find better steering response with one on my car. It did like to hit things occansionally. Some of the slop of the old oem LCA bushings might have been why it seemed to help so much....cant answer that one.
Old Dec 16, 2002 | 07:29 AM
Knestis's Avatar
... looks cool though.
Which is really the whole point, isn't it?
Kirk
Old Dec 16, 2002 | 08:19 AM
Joon525's Avatar
Yeah but if the shocks compress it can still hit something. Oh well.....this is my next purchase for the Prelude.
Old Dec 16, 2002 | 01:06 PM
i take a lot of driveway aprons & speed bumps sort of sideways, that is, one wheel at a time, to avoid scraping frame and/or itr header/shield. i think such a bar would get rocked the first time i did something like that.
my car's not that low either.
chances are, if it could happen, it would happen to me.
Old Dec 16, 2002 | 01:19 PM
Mojo-Jojo's Avatar
I've got the Benen bar. Ch***is dyno says the steering felt a little more responsive with it on.
And I've never had a problem with it scraping on anything. Because of the way it's shaped and mounted it's barely lower than any of the other parts of the car.
Old Dec 16, 2002 | 09:53 PM
EGTeK's Avatar
Default Re: Anyone using FRONT lower tie bars? (Mojo-Jojo)
do you guys have the stock gsr front lower ties on?
Old Dec 16, 2002 | 10:09 PM
Reza.dc's Avatar
Default Re: Anyone using FRONT lower tie bars? (92CXHB)
Mojo : what size bolts did you use for your bar? thanks for the info..
707CIVIC
Suspension & Brakes
May 1, 2008 02:01 PM
kkim
Apr 25, 2004 06:00 PM
JDMjames
Jul 2, 2003 09:41 AM
itr98spec
Apr 2, 2003 09:57 PM
