h22's with a upgraded flywheel
Old Dec 15, 2002 | 06:25 AM
MrBui's Avatar
Default h22's with a upgraded flywheel
does ur car sometimes struggle to engage and make sounds like the car is already running and ur trying to start it up? i tired replacing the starter but it still made the same sound....what could be the problem? the flywheel itself?
Old Dec 15, 2002 | 08:33 AM
Anubyss's Avatar
Default Re: h22's with a upgraded flywheel (n20need4vtec)
This is a know issue with a lot of lightened flywheels. I have a Fidanza flywheel and have the same issue. It's because the teeth on the starter doesn't line up properly with the teeth on the flywheel. I've heard the solution is to file down the teeth on the starter or the flywheel itself. I don't know anyone that has actually done this or seen the results of something like this.
Old Dec 15, 2002 | 08:41 AM
Joon525's Avatar
Default Re: h22's with a upgraded flywheel (Anubyss)
It's funny, not everyone's does this but it's very common. My friend has the Fidanza and no problems at all.
Old Dec 15, 2002 | 09:19 AM
piotrush's Avatar
I heard this happens on JUN flywheels because they are made for jdm starters, but I've never heard of it happening on a Fidanza. That was the biggest reason I was planning to go with Fidanza over JUN. I hope the problem lies in the instalation and not the flywheel itself.
Old Dec 15, 2002 | 09:41 AM
92 in the works's Avatar
Default Re: h22's with a upgraded flywheel (piotrush)
I've had my clutchmaster's flywheel on for about 3 weeks now and I haven't experienced any problems like that.
Old Dec 15, 2002 | 01:53 PM
DarkJedi's Avatar
Default Re: h22's with a upgraded flywheel (92 in the works)
i have the jun ultralightweight flywheel and i have not had any problems like that, i am using the jdm starter that came with my engine
Old Dec 16, 2002 | 05:47 AM
piotrush's Avatar
Default Re: h22's with a upgraded flywheel (DarkJedi)
Thats probably why. Does anyone know how much a JDM starter would cost? Would it be worth modding it to work with a JUN fw?
Old Dec 22, 2002 | 11:46 PM
p10hlm's Avatar
I have a stock flywheel and sometimes when i start my car it cranks normal
,grinds like im trying to start it while its already running,then starts right up................a couple of times it wouldnt start for **** i had to push start the dam
thing ...........that sux when its 7:30 am (on my drive to work im half a sleep has it is )
Old Dec 23, 2002 | 08:11 AM
MPower332TI's Avatar
Default Re: h22's with a upgraded flywheel (p10hlm)
I dont think it has anyting to do with a jdm flywheel. I have a 94 jdm H22 and a clutch masters lightweight flywheel, starts fine everythime.
Old Dec 23, 2002 | 08:22 AM
bgod's Avatar
Default Re: h22's with a upgraded flywheel (jDmDxTuRd)
i used to have this same problem on my old h22a accord. it started up fine for a week or so. then the teeth didn't start engaging as well.
the car was like this for a good year or so and it would start on the 2nd or 3rd try everytime.
Old Dec 23, 2002 | 10:29 AM
TypeSH's Avatar
Default Re: h22's with a upgraded flywheel (bgod)
have you guys tried a diff starter? maybe your starter is going bad?
or anyone try a JDM starter? get one off one of the guys w/ a JDM h22A?
wakaranai
17
Sep 14, 2016 07:02 PM
SpoolnG2
Dec 27, 2002 11:49 AM
lilcasino
Aug 4, 2002 08:25 AM
lilcasino
Aug 4, 2002 12:52 AM
quick108
Jul 13, 2002 02:18 PM
