n e opinions on wat to put for my EG to run 13's N/A pls help?
Old Dec 14, 2002 | 01:15 AM
OLM-02R's Avatar
Default n e opinions on wat to put for my EG to run 13's N/A pls help?
hey guys.....just wanted to get some ideaz on what to put on my EG to run 13's??? i got b18c1 block with b16a head....pls holla back peace...
Old Dec 14, 2002 | 03:20 AM
jdmDXrex's Avatar
Default Re: n e opinions on wat to put for my EG to run 13's N/A pls help? (OLM-02R)
with slicks you should be there... if not you should be pretty damn close. just like the wraith said if you are staying N/A compression with the combination of cams (more air) will help out the most. but then if you go high enough on the CR and Cams you will need more fuel i.e. injectors, fuel pump etc.... basically u get the point the more you build you motor the more $$$ you will have to spend.
if you are just looking to hit 13's I would just do the easy bolt ons I/H/E and slicks. clutch will help if you want to run slicks. ACT HD pressure plate and 6 puck disk is still very streetable. that should easily get you into 13's. Good Luck
.adam.
Aug 23, 2005 03:29 PM
ferio 95
11
May 1, 2004 09:30 AM
95JDMride
Oct 16, 2003 04:48 PM
B_1_8_hatch
15
Aug 9, 2003 09:24 AM
