How to fit a Neuspeed lower tie with a ST rear sway
Old Dec 13, 2002 | 07:06 PM
shawnhayes's Avatar
Default How to fit a Neuspeed lower tie with a ST rear sway
I've been told it can't be done.
Garbage.
You have to machine off the excess material around the lower brackets. It takes a while, and definately some patience and skill, but before the Comptech kit, and recently ST kit, this was about the only way to do it.
Shawn
Old Dec 13, 2002 | 08:29 PM
purplehazek4's Avatar
Default Re: How to fit a Neuspeed lower tie with a ST rear sway (shawnhayes)
i actually had the same exact setup with my old car. what i did was use a 1 inch spacer on the bolts where the lower tie bar goes(making the tie bar sit further out)
that will give you the clearence you need
Old Dec 14, 2002 | 04:20 AM
shawnhayes's Avatar
Default Re: How to fit a Neuspeed lower tie with a ST rear sway (purplehazek4)
Did you get longer bolts for that?
Shawn
[HrZn]4life
Dec 5, 2004 06:30 PM
