looking to raise compression in my b16
Old Dec 13, 2002 | 03:29 PM
EFing8's Avatar
Default looking to raise compression in my b16
What OEM honda pistons will raise the compression to 10.8 - 11:1 compression?
Old Dec 13, 2002 | 03:44 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: looking to raise compression in my b16 (CND_CRX)
now sure about it
but a gsr head should raise your compression
Old Dec 13, 2002 | 03:48 PM
customx_'s Avatar
New User
thinner head gasket
aftermarket pistons/rods
welded chambers
Old Dec 13, 2002 | 03:50 PM
ExospeedAMcrx's Avatar
its already about that high of a CR. are you thinking of 11:1+ CR, then a CTR piston would work.
Old Dec 13, 2002 | 04:07 PM
EFing8's Avatar
Default Re: looking to raise compression in my b16 (exospeedAMcrx)
How high would the CTR pistons bump my compression to?
Old Dec 13, 2002 | 04:08 PM
EFing8's Avatar
And i thought stock b16 compression was 10.2:1
Old Dec 13, 2002 | 04:22 PM
PhatOptimo's Avatar
They will put you at roughly 11.1:1 CR. I have them in my B16a. They do fine on pump gass (93 octane).
Old Dec 14, 2002 | 01:37 PM
SiR831's Avatar
Default Re: looking to raise compression in my b16 (Phat_Optimo)
what all have you done to your B16a besides the CTR pistons. Did it make a big difference and what kinda times are you hitting in the 1320.
Old Dec 14, 2002 | 01:45 PM
CHRIS 1.8's Avatar
GSR head and headgasket
Old Dec 14, 2002 | 02:35 PM
joe crxb18c1s1's Avatar
Instead of Itr pistons you may want to look into milling the head. I would suggest it if its your daily driver
Old Dec 14, 2002 | 04:00 PM
Pat McGroin's Avatar
Default Re: looking to raise compression in my b16 (joe crxb18c1s1)
1 layer headgasket- $120
Spoon Jdm ITR pistons w/rings $300-330
lsvtec_hatchback
Aug 25, 2006 02:18 PM
. WAAS_SAPPENING
15
Jun 12, 2006 06:51 PM
Spyderman4g63
Apr 27, 2005 01:23 PM
hondacrx90
Jun 21, 2004 06:06 PM
riceball777
May 6, 2003 06:04 PM
