1990 D16a6 Engine/Transmission (CRX Si) - Bay Area CA
From: A place where stupidity runs rampant aka NorCal
1990 D16a6 (CRX Si)
Very Strong motor - selling because I put a B16a into the car.
Includes:
Energy Suspension Engine mounts
New timing belt
New timing belt tensioner
New Water Pump
New thermostat
New head Gasket
New intake/exhaust manifold gaskets
New Injector Seals
New Throttle body gasket
Hot tanked head (very clean, no deposits on valves)
Head Milled .0060, raises compression approx .5
New Spark Plugs
New Spark Plug wires
New Distributor cap
New pass. side axle (Both included - Drivers side is fine)
1991 CRX Si transmission
Paid $300 one month ago from Auto Recycler
No grinds
Exedy Organic Clutch - New
Exedy Pressure plate - New
New t/o bearing
New Pilot bearing
Located in Livermore, CA at Diablo Autosports, ready for pickup today!
$450 for both
or (Dont really want to seperate but if I have to)
$200 motor
$300 Transmission
toddvwvr6@aol.com
[Modified by Count Blah, 5:55 PM 12/14/2002]
Includes:
New timing belt
New Water Pump
New thermostat
New head Gasket
New Injector Seals
New Spark Plugs
New Distributor cap
No grinds
New t/o bearing
New Pilot bearing
$450 for both
$200 motor
$300 Transmission
toddvwvr6@aol.com
If you are interested please PM me and ill supply the VIN, im a bit hesitant to post the VIN of my car on the internet.
Thanks!
-Todd
Thanks!
-Todd
The block has 170k, the head has 100k and the transmission has low mileage (i dont know exactly how much as i just bought it a month ago and all the recycling yard said was "low")
The pistons were in immaculate shape when i pulled the head to put a new head gasket on (i snapped a spark plug off the old head when changing plugs, so i got a low mileage head instead of bothering trying to get the seized plug out).
Compression was 180 across the board, does not burn a drop of oil, i was running Synergyn at the time.
-Todd
-Todd
mykoe817
Jul 19, 2007 05:30 PM
