anyone using the brake booster for their wastegate???
Old Dec 13, 2002 | 11:51 AM
DIY_Racing's Avatar
Default anyone using the brake booster for their wastegate???
I need a vacuum source for my wastegate. anyoje using their brake booster hose.??
and if you are, how did you do it... just a giant tee into a smalller fittin??? just curious.
Old Dec 13, 2002 | 01:39 PM
B18EG6's Avatar
Default Re: anyone using the brake booster for their wastegate??? (DIY_Racing)
I didnt use the booster for my source, but yes...just use a tee reducing thingeemabobwhosit
Old Dec 13, 2002 | 02:19 PM
DeepSi's Avatar
Default Re: anyone using the brake booster for their wastegate??? (B18EG6)
i believe i am, i forgot where i hooked mine up at me. but i am almost positive.
Old Dec 13, 2002 | 03:32 PM
93LSivic's Avatar
I am, and I believe it works better since its a larger line. Wastegate, when running off its spring, seems to open later in boost --a good thing.
Yeah, just use a reducer T . Make sure you put it in between the manifold and the check valve or bad things can happen!
Old Dec 13, 2002 | 04:02 PM
justinCO's Avatar
Default Re: anyone using the brake booster for their wastegate??? (93LSivic)
My WG is on the brake booster vac. I followed 93LSivics suggestions from a post he made a while ago. I got a T that tapers from big to small and you cut it for your particular size hose that it's connecting to. Got it at Checker...
Justin
Old Dec 15, 2002 | 05:45 PM
DIY_Racing's Avatar
ANyone have any pics of their setup????
Old Dec 15, 2002 | 07:29 PM
turbolscivic94's Avatar
Where do you think would be better, the brake booster, or the line that goes from the manifold to the fuel pressure regulator? I was gonna tap from the manifold, but may change if its gonna cause a problem.
Old Dec 15, 2002 | 07:31 PM
CzanSOHC's Avatar
Default Re: anyone using the brake booster for their wastegate??? (turbolscivic94)
use the FPR vac line for BOV and Boost gauge. I am going to be using the Brake booster line for my wastegate.
Old Dec 16, 2002 | 04:47 PM
CalvitoSol's Avatar
Default Re: anyone using the brake booster for their wastegate??? (CzanSOHC)
i recently moved my bov and tial to the brake booster line and now, my bov works perfectly. the turbo's response is much quicker but i couldn't tell any difference on the wastegate. i went to home depot looking for some reducers but had no luck. after looking around the air compressor section, i came across some called an "air compressor manifold" this basically a small unit that has one large port that hooks up to the main vac. line and 3 smaller ports to hook up barb fitting that splits into other vac lines. all in all, i'm pretty satisfied w/ its function and has a bit of a bling factor to it too i'll try to post pics asap
Old Dec 16, 2002 | 04:51 PM
khang77642's Avatar
Default Re: anyone using the brake booster for their wastegate??? (theory48)
yeah pics
Old Dec 16, 2002 | 05:29 PM
TurboedGSR's Avatar
Default Re: anyone using the brake booster for their wastegate??? (khang77642)
i tought i was the only one that did that
heres a pic of mine...i know i need to get rid of the fmu
Old Dec 16, 2002 | 06:15 PM
vtec.dc2's Avatar
Default Re: anyone using the brake booster for their wastegate??? (TurboedGSR)
that pic doesn't work
Old Dec 16, 2002 | 06:20 PM
Sprockets's Avatar
I bought one of those plastic universal T fittings that you just trim down to the size you need. It was flimsy, the opening just didn't seem large enough and I didn't trust it. I went to Home Depot and spent a few bucks more for some good brass fittings and hose clamps.
Get this female T fitting in 1/4":
Then get 2 of these fittings in 1/4" x 3/8" and 1 in 1/4" x 1/4":
Get some teflon tape and 2 hose clamps and you're done!
Old Dec 16, 2002 | 07:02 PM
TurboedGSR's Avatar
Default Re: anyone using the brake booster for their wastegate??? (vtec.dc2)
i guess yahoo wont let me link off their site
Old Dec 16, 2002 | 08:36 PM
philo's Avatar
Why does your wastegate need a vacuum source, are you talking about your blow-off valve?
Old Dec 16, 2002 | 08:44 PM
b18bvudoo's Avatar
New User
Old Dec 16, 2002 | 08:48 PM
CzanSOHC's Avatar
Default Re: anyone using the brake booster for their wastegate??? (b18bvudoo)
uhhh....
Old Dec 16, 2002 | 08:49 PM
philo's Avatar
Is all that silicon hose going to a boost controller?
Old Dec 16, 2002 | 08:53 PM
CzanSOHC's Avatar
Default Re: anyone using the brake booster for their wastegate??? (philo)
the top one is going to the boost controller and the side one is the vacumm sorce as you can see tapped into the brake booster.
Old Dec 16, 2002 | 08:59 PM
philo's Avatar
I cant see how thats an efficient way to do it, but if it works...
Old Dec 17, 2002 | 12:28 AM
lilxvtecxpwr's Avatar
what if u dont want to use a boost controller? would u just leave the fitting on top of the wastegate unplugged?
also, what is the difference between hooking up the wastegate vaccuum to the little hole on the side of the compressor housing instead of the brakebooster?
Old Dec 17, 2002 | 05:39 AM
TurboedGSR's Avatar
Default Re: anyone using the brake booster for their wastegate??? (lilxvtecxpwr)
if you use the port on the compressor housing, the wastegate will read boost at the compressor. pressure is lost going through the intercooler so the manifold won't see the same pressure as the wastegate.
if you have a MBC, then you can do it
Old Dec 17, 2002 | 08:43 AM
DIY_Racing's Avatar
Now im alittle confused... Tell me if im wrong or right.
If you are using a manual boost controller, you run a line from the SIDE of the wastegate to the controller to the vacuum on the manifold. And you leave the top fitting alone.
If you are using an ELECTRIC wastegate that is when you use the top fitting..
correct???
Oh, and i didnt know that BOVs needed a vacuum source. I thought they just worked by themselves....
Old Dec 17, 2002 | 11:46 AM
philo's Avatar
The job of a wastegate is to regulate the pressure at the turbine, not the pressure at the manifold. The lower port of the wastegate should be feed from the turbo compressor or as close as possible.
The MAP sensor line that goes to the boost controller needs to see vacuum and should be tapped directly off the intake mani.
All runs of vacuum hose should be kept as short as possible to reduce latency, especially with embedded logic boost controllers.
The top port of the wastegate goes to the boost controller solenoid and needs to be as short as possible also.
Many different setups will work but some may result in boost spikes or poorer performance from your boost controller.
[Modified by philo, 2:51 PM 12/17/2002]
Old Dec 17, 2002 | 11:52 AM
PM-Performance's Avatar
hmmm , i was just gonna tap all my vac lines off my port from the im to the fpr too .
you think for the wg and bov it will make a diff to get vac sourde from the booster?
im lost now ? i thought i had it all down then you guys came up with this?
is there really a diff as long as it gets vac?
