What is the best front camber kit? What are most peopl using?
Old Dec 13, 2002 | 10:09 AM
Civichatch2k's Avatar
Default What is the best front camber kit? What are most peopl using?
Well i went to aline my car today, and they got it as best they could but with the progress camber kit on the front and back i am still negetive camber...the front is like 2 degrees, so i need to upgrade the front for sure....I know that raising the car will help alot so that is already on the table but what is a good kit to go with?
.Ryan's Avatar
Don't Trust Anyone
Default Re: What is the best front camber kit? What are most peopl using? (Civichatch2k)
I have a new Progress kit for sell.
any information would help me greatly. Thanks alot.
Old Dec 13, 2002 | 10:16 AM
sivik2nr's Avatar
Yeah, what about the Progress Technology front and rear kit? I think Landspeed Racing is selling it for like $189 for both front and rear kits.
How's the adjustability?
Old Dec 13, 2002 | 10:18 AM
.Ryan's Avatar
Don't Trust Anyone
Default Re: What is the best front camber kit? What are most peopl using? (sivik2nr)
Im selling the Progress F/R camber kit $150+shipping...new....box has been opened.
Old Dec 13, 2002 | 10:20 AM
u2civic1's Avatar
Ingalls are pretty good, if you get the poly ones which are more sporty they tend to make some noise. i like the rubber ones. i think groupbuycenter has them for sell right now. Also you can always get the shrunk 2 ones which are cheap and work well. But don't get the cheap ebay ones that are like 15 bux
Old Dec 13, 2002 | 10:21 AM
darkknightwong's Avatar
I have the SKUNK2 on my car.
Its been working great...
I have a 99 Civic SI
DK
Old Dec 13, 2002 | 10:30 AM
i have the progress kit on the car now and i personally dont see it really doing much....the front kit it turned to it's max and the rear is also...What about skunk 2 anyone heard anything about them?
Old Dec 13, 2002 | 10:31 AM
Default Re: What is the best front camber kit? What are most peopl using? (darkknightwong)
DK
cool that is what i was hoping to hear because i like their set up.
Old Dec 13, 2002 | 10:44 AM
92hatchdude's Avatar
I am using an Ingalls kit with rubber bushings. The kit works well but mine make a little noise sometimes. I prolly just need to try to lube them or somthing. I think I paid 145 for the front\rear kit.
Old Dec 13, 2002 | 10:50 AM
jdmEKhb's Avatar
Default Re: What is the best front camber kit? What are most peopl using? (92hatchdude)
Skunk 2
Old Dec 13, 2002 | 12:15 PM
monicle's Avatar
Specialty Products are money. The dude that adjusted my camber/toe really liked em too.
Old Dec 13, 2002 | 12:22 PM
WAFFLES's Avatar
Default Re: What is the best front camber kit? What are most peopl using? (monicle)
Skunk2 are good, but not very good for racing. They need to be notched so they don't slip...but for daily driving, they are cool.
Old Dec 13, 2002 | 12:31 PM
n1ek's Avatar
i run the "no" camber kit.
it has 0 degrees od adjustment.
but, it doesn't rub. it was real easy to install and -2 degrees was liveable.
the only problem with a kit is this:
if you actually have -4 deg. camber your car is LOW, and putting the car back to 0 deg. will make the tires rub. oh, and you can't get back to 0deg. with no rubbing if you don't raise the car. i just make sure to run proper toe and caster and keep an eye one the tires...as long as you rail alot of corners, you get even tire wear.
Old Dec 13, 2002 | 12:33 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: What is the best front camber kit? What are most peopl using? (n1ek)
Skunk2.
Love mine, no problems for 2 years.
Old Dec 13, 2002 | 12:58 PM
silverEH2's Avatar
Default Re: What is the best front camber kit? What are most peopl using? (B18C-EJ1)
i have the ingalls, it is a little noisy after it rains, also i have to lubricate it every 2 months, other than that no complaints
Old Dec 13, 2002 | 03:12 PM
scdarksol's Avatar
put some washers in between your rear upper control arms, instead of wasting your money on a rear camber kit. It fixes your rear camber for couple cents! Did fine for me!
Old Dec 13, 2002 | 03:37 PM
Default Re: What is the best front camber kit? What are most peopl using? (scdarksol)
thanks for the idea but i already have a progress kit....it is not doing the job...that is what this post is about.
TeGGY_LS
Nov 6, 2003 10:46 PM
watacivic
13
Oct 8, 2002 09:15 PM
PnX-R
Apr 28, 2002 03:37 PM
