How Do I Clean My Engine bay!??!
Old Dec 13, 2002 | 08:04 AM
gleinz's Avatar
Default How Do I Clean My Engine bay!??!
Aight, I know how to, just had one question about it:
I have a citrus based engine degreaser, will that remove the corrosion resistant material that some of the parts are coated with? I've been told that it's pretty mild, and that it shouldnt do any harm. Just wanna make sure before I go clean my bay.
Old Dec 13, 2002 | 08:09 AM
rainmanEK's Avatar
big strong guy
Default Re: How Do I Clean My Engine bay!??! (gleinz)
Should work fine
I use GUNK, or Some kinda purple stuff
My friends and I have very clean motors
good luck, eric
Old Dec 13, 2002 | 08:13 AM
Brian's Avatar
You should be ok. I use automotive Simple Green and just spray it all over and let it sit for 5 minutes. Agitate the dirt and rinse. Real easy.
Old Dec 13, 2002 | 08:17 AM
.Beaver's Avatar
Bloody Beaver
Default Re: How Do I Clean My Engine bay!??! (Brian)
Is there anything you have to watch out for, like wiring, ignition, etc... that shouldn't be wet?
Old Dec 13, 2002 | 08:19 AM
Black_eh2's Avatar
New User
Default Re: How Do I Clean My Engine bay!??! (rainmanEK)
simple green is fine with me
Old Dec 13, 2002 | 08:22 AM
emr88's Avatar
Default Re: How Do I Clean My Engine bay!??! (93 MR EJ1)
Follow the steps listed on this website, I guarantee that you will be amazed with the results. I substituted Meguiars Vinyl and Rubber cleaner/protectant instead of Amor All-turned out great.
http://www.apexcone.com/TechProcedur.../ArmorAll.html
You can place a plastic bag around your distributor to be safe.
Old Dec 13, 2002 | 08:39 AM
94HybridEX's Avatar
Default Re: How Do I Clean My Engine bay!??! (emr88)
I cleaned the heavy **** with gunk remover. Then I got some stuff called "Foamy Engine Bright". You make sure the engine is COLD and dry, cover up electronics and air filter, then spray all over. Let it foam for about 10 minutes and scrub tough spots. Then hose off by sprinkling water.
My engine looks real dope now.
Old Dec 13, 2002 | 09:01 AM
Shawn C's Avatar
In The Garage
Default Re: How Do I Clean My Engine bay!??! (94HybridEX)
yeah i use like 2 cans of foaming engine cleaner, just keep covering **** until the cans are empty, concentrating on the nasty areas. (this is mainly the first time i clean an engine on one of my cars, just keep it spotless after that). kindof be careful of the distributor, and the area in between cams on the v/c, other than that, let the foamy stuff sit for like 5 mins, then pressure wash off. let everything dry really good, take it for a drive, then i put black magic tire shine (the good smelling ****) on a rag and wipe the hoses with it. blingin yo. pimp tiiite stunnariffic
Old Dec 13, 2002 | 09:07 AM
Brian's Avatar
I don't and haven't had any problems.
JDM92CX's Avatar
Default Re: How Do I Clean My Engine bay!??! (22lbGS-R)
I use Brake Cleaner on the tranny and block, But be careful not to get it on any paint or it will strip it right off. Then I use Simple Green to clean the rest of the engine off with.
Old Dec 13, 2002 | 09:39 AM
degooser's Avatar
So, your saying that the only thing that you need to cover when spraying water on your engine is the distributor?
Old Dec 13, 2002 | 09:50 AM
EVIL Hx Coupe's Avatar
Default Re: How Do I Clean My Engine bay!??! (degooser)
Yes, and the air filter if u have a shortram.
Old Dec 13, 2002 | 11:12 AM
jdmEKhb's Avatar
Default Re: How Do I Clean My Engine bay!??! (Boost Pressure)
Yea use that stuff along with taking it to your local cash wash place to use the pressure washer, it works hella good!!! Just cover your distibutor and spark plug wires!
Old Dec 13, 2002 | 12:03 PM
Shawn C's Avatar
In The Garage
Default Re: How Do I Clean My Engine bay!??! (jdmEKhb)
yeah, just the gap between the distributor and the distributor cap. if it gets water in there, you could have some ignition problems. i never cover it with plastic, but i make sure not to concentrate pressure on it.
Old Dec 13, 2002 | 12:24 PM
Chris y0!'s Avatar
simple green own3z joo.
Old Dec 13, 2002 | 12:25 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: How Do I Clean My Engine bay!??! (SleeperEG6)
Old Dec 13, 2002 | 02:01 PM
mantic6t9's Avatar
Default Re: How Do I Clean My Engine bay!??! (B18C-EJ1)
Simple Green, wire brush, tooth brush, rags, synthetic steel wool, anything else that may be useful. It took a few intense scrubings/washings to get mine clean. Once you get it clean all you should really have to do is spray degreaser, let it sit, and rinse off. Do this atleast once a month and it should stay fairly clean.
Here is what mine looks like now.
Good luck...
Old Dec 13, 2002 | 02:03 PM
smnowell's Avatar
Default Re: How Do I Clean My Engine bay!??! (mantic6t9)
DAMN! That is one clean engine bay! I think I might take some time out this weekend and clean mine up as well Where can you buy Simple Green?
Old Dec 13, 2002 | 02:07 PM
NonovUrbizniz's Avatar
Loved
DAMN that looks good. (especially the fuel rail and regulator... mine look like ish still.)
I recomend using FOAMING simple green it's new and it rocks... plus it's not flammable like the other stuff so you can spray it on while the engine is hot (this makes it more effective) spray it down good only complaint would be is you may have to use two cans. Also simple green is biodegradable (not like what you clean off is but at least it's not both dirt and cleanser)
And ya I wrap the wires and distributer with ceran wrap. works great... I've never had a problem when I didn't use it though.. however a friend of mine with a vw did. it turned out that one of his ground wires was kinda shaky as it was then when it got wet it was ill-plapla till it dried.
Old Dec 13, 2002 | 02:30 PM
gleinz's Avatar
Default Re: How Do I Clean My Engine bay!??! (NonovUrbizniz)
so u can just hose down your engine bay as long as the distributer is covered? just wondering cus i got a pressure washer and could make good use of it
oh yeah, where do i get automotive simple green? we're limited to auto parts places here... like our napa is the size of my bedroom which aint very big.
[Modified by gleinz, 6:31 PM 12/13/2002]
Old Dec 13, 2002 | 02:47 PM
b18C1_liLkyLe's Avatar
dzzzzzzzzamn!!! very nice engine bay homeeeey! mine is gettin madd dusty. (i know i.m an integ owner, but i hoped to see some nice ek's in here)
Old Dec 13, 2002 | 05:19 PM
AmginE's Avatar
Default Re: How Do I Clean My Engine bay!??! (b18C1_liLkyLe)
in that thread about engine cleaning, i HATE that greasy look. bleh, simple green and scrubbing works well.
Old Dec 13, 2002 | 05:25 PM
DOMKID's Avatar
Default Re: How Do I Clean My Engine bay!??! (AmginE)
Do you guys do the same thing when the engine is outside the car, like when you are doing a swap?
Old Dec 13, 2002 | 05:33 PM
gleinz's Avatar
Default Re: How Do I Clean My Engine bay!??! (Dominican_Kid)
I say again, can I just hose down my engine bay if I cover the distributor?
Old Dec 13, 2002 | 05:41 PM
emr88's Avatar
You don't *have to* cover your dist, but it only takes a second to cover it up with a cheap plastic grocery bag. Just don't spray (especially with a pressure nozzle) directly at the distributor & wires. Also, the Amor All will give it a 'greasy' look, but you can wipe it down with a rag once everything is dry and it won't look 'greasy', just clean like the way it came off the dealer lot.
