O2 Sensor Wiring Flipping
Old Dec 13, 2002 | 07:04 AM
EF8_SiR's Avatar
Default O2 Sensor Wiring Flipping
After some research I've concluded that it is quite possible that the o2 sensors on my B16 is reversed. Reading on HT and on net, ppl just mentioned about flipping them to correct the "rich" problem.
What I don't understand is flip them at what point? I see 2 possible locations
1) At the exhaust manifold (switching the location)
2) Actually disconnecting at the plug part (by the tranny), but at the moment I have the green to the green and white to white which seems logical
For anyone who's done this, where was the flip made?
Thanks
Old Dec 13, 2002 | 07:46 AM
PhatOptimo's Avatar
Default Re: O2 Sensor Wiring Flipping (EF8_SiR)
cut the wires in the engine bay side. Strip them put some shrink wrap on the wire and solder them back together. Slode the shrink wrap over the silder joint and heat it up so it seals the joint. HTH
Old Dec 13, 2002 | 08:00 AM
EF8_SiR's Avatar
Default Re: O2 Sensor Wiring Flipping (Phat_Optimo)
So what ur saying is between the actual o2's and the connecting plugs I do the switch at that point?
But why go through that when it would more stable to just switch the slots on the exhaust manifold? Is there a benefit or something I dunno?
Old Dec 13, 2002 | 08:45 AM
MADEINIRAQ's Avatar
switch the pins on the ecu
pins c8 and c16.. it is very easy and takes about 5 minutes or less
not wire cutting and splicing.
Old Dec 13, 2002 | 09:26 AM
PhatOptimo's Avatar
Default Re: O2 Sensor Wiring Flipping (madeiniraq)
Do whatever is easiest. Its not easy taking the o2s out and swithching them when the header is on the motor (damn near impossible). Switching ECU pins is a PITA 2 me. I am good with a torch so it takes about 1 minuite 2 solder 2 wires. Do you need some MILK with your cake job?
Old Dec 13, 2002 | 09:32 AM
EF8_SiR's Avatar
True, replacing o2's was a bitch and I rather not make so much work out of the process. Most likely switch the ecu pinouts. Hmm, didn't think of that solution b4.
Hybrid94Hatch
15
Nov 5, 2011 09:27 PM
patastinky
Jul 19, 2005 01:24 PM
Hyjnx
Sep 24, 2004 02:22 PM
EF8_SiR
Aug 15, 2002 09:40 AM
Pinhead
Jan 13, 2002 05:17 PM
