code 6
Old Dec 13, 2002 | 06:14 AM
Rob!'s Avatar
Default code 6
did anyone ever throw a code 6 (coolant temp) in their pr3 ecu...im throwing a code 6 after just putting my motor in and my car is bogging so bad and i dont know if its wireing or mechanical problem
Old Dec 13, 2002 | 06:34 AM
USDM 4G VTEC's Avatar
Default Re: code 6 (RaceFacer)
check the lil bullet conector found close to the dizzy, on the side of the head.. that tells the ecu the coolant temperaturre... if its diconected , thats maybe why its trowing u a code...
Old Dec 17, 2002 | 06:34 PM
blackEF's Avatar
Default Re: code 6 (JDM EF9)
If your temp gauge isnt working then that would maybe narrow the problem down to the sensor not being plugged in right under the distributor. (1 prong connector)
dimension4
Jan 26, 2007 08:14 AM
mprelude
Jan 10, 2005 11:52 AM
MPALUGHI
Jan 7, 2005 05:11 AM
4gnhatch
Jun 2, 2003 12:35 PM
SpoonPL
Sep 27, 2002 07:39 PM
