What size socket do I need for the axle/hub nut?
Old Dec 13, 2002 | 04:50 AM
DX Hybridizer's Avatar
Default What size socket do I need for the axle/hub nut?
Just like it said that big motha nut on the front connecting the driveshaft to the hub/brakes.
I need to go buy that socket tonight to pull my driveshafts out why pulling this motor. A friend told me it's a guesstimate of a 1 1/8 American worked best for him does this sound right. What is the MM equivilant if it is indeed MM.
Thanks guys!
Old Dec 13, 2002 | 05:14 AM
PSU-TEG's Avatar
Default Re: What size socket do I need for the axle/hub nut? (DX Hybridizer)
Well, I'm not 110% sure about your car.....
But for my axles it was 1 1/4" I would guess that your's would be the same but I'm not sure.
Anyway... here is your conversions:
1" = 25.4 mm, therefore:
1 1/8" = 1.125" = 28.575 mm
1 1/4" = 1.25" = 31.75 mm
[Modified by PSU-TEG, 9:15 AM 12/13/2002]
Old Dec 13, 2002 | 05:17 AM
Default Re: What size socket do I need for the axle/hub nut? (PSU-TEG)
That sounds about right since I just asked a friend who has done plenty of swaps what he thought it was and said he used a 32MM socket. Maybe I'll pick up one of both cause god knows I don't want to round that nut!
Thanks
Old Dec 13, 2002 | 05:18 AM
b19coupe's Avatar
32mm for all Integra's.
Old Dec 13, 2002 | 05:30 AM
PSU-TEG's Avatar
Default Re: What size socket do I need for the axle/hub nut? (b19coupe)
That's what I heard too.... but to be honest with you... I tried both 32mm and 1 1/4" socket.... and the 1 1/4" fit perfectly. The 32mm had a little play in it (but just a little, it would have worked... but why not use the best fit.)
So take it for what it is worth... if you have them both, maybe try both. Maybe my axle nut was just a little worn or something, so the 1 1/4" made a better fit. Don't know how it got worn, but after all we are only talking about 0.25mm.
[Modified by PSU-TEG, 9:31 AM 12/13/2002]
Old Dec 13, 2002 | 05:32 AM
Hondasaurs's Avatar
32 mm, I've swapped two engines (in Civics) in the past week and they both used a 32mm on the axel
[Modified by ZC_CRX, 9:32 AM 12/13/2002]
Old Dec 13, 2002 | 07:06 AM
Desslok's Avatar
Default Re: What size socket do I need for the axle/hub nut? (ZC_CRX)
Should be 32, you can borrow one at Autozone for free, just put deposit down. THat's what I did about a month ago.
Old Dec 13, 2002 | 07:46 AM
RosSi's Avatar
New User
32mm and a big-*** breaker bar.
Old Dec 13, 2002 | 07:50 AM
1bad-eg's Avatar
Default Re: What size socket do I need for the axle/hub nut? (RosSi)
one big fat 32mm
Old Dec 13, 2002 | 09:34 AM
Ricky Rojales's Avatar
If you don't have one, then borrow it from autozone for free.
Old Dec 13, 2002 | 09:35 AM
Default Re: What size socket do I need for the axle/hub nut? (Ralphie)
I'm just going to buy one There will be plenty of times I can see me needing this size socket and well it's always good to expand your tool sets anyways. Thanks for the help guys, I appreciate the fast quick responses.
CarBug
Jun 9, 2016 01:44 PM
EG6_978
17
Mar 18, 2009 10:16 AM
98ITR#0020
May 31, 2003 07:06 AM
Aeka GSR
Jan 17, 2003 04:49 PM
CIVIX
Mar 25, 2002 02:55 PM
