Intake "squeal" from short ram
Old Dec 12, 2002 | 09:27 PM
jwasi's Avatar
Default Intake "squeal" from short ram
I have a b18c with a generic short ram intake and K&n filter. Whenever I hit the gas the car "squeals" a really high pitched uncool girly squeal. Anyone have any ideas on how I can put a breather on it or somthing?
Old Dec 12, 2002 | 09:49 PM
Kamin's Avatar
Default Re: Intake "squeal" from short ram (jwasi)
that could be your problem.
doublecheck all your clamps to be sure.
Old Dec 12, 2002 | 10:08 PM
SupaTegRS's Avatar
Default Re: Intake "squeal" from short ram (Kamin)
I have an old style AEM short ram, and I get the same noise.....I don't think theres any way around it. Sounds almost like a mini blow off valve or something. I think its just generated by the sudden induction of air when the throttle is pressed.....dunno though.
I made sure my connections were tight, and they all checked out...standing with the hood open, I blipped the throttle and the noise is definately coming from the filter.
I don't find the noise to be too annoying, so I'm not gonna worry bout it.
Old Dec 13, 2002 | 12:56 AM
jwasi's Avatar
Default Re: Intake "squeal" from short ram (SupaTegRS)
First of all, thanks both of you for your quick responses...
Sounds like your car makes the same sound, I wish it didn't bother me ;(
I checked all my fittings and gaskets, they are all tight. Without the K&N it still squeals, maybe it is just a bad shape or somthing?
Old Dec 13, 2002 | 02:22 AM
texan's Avatar
A friend of mine has the same thing on his short ram (B16A), I believe it's just a byproduct of the basic setup. Either go back to stock or get a full length CAI to get rid of the noise.
Old Dec 13, 2002 | 04:58 AM
PSU-TEG's Avatar
Default Re: Intake "squeal" from short ram (texan)
Yep... that is typical on a aftermarket intakes.
They act almost like a wind instrament. From the design of the the intake, the certian size an legth, it will emit a certain tone.
I have a cheep Ractive Short Ram intake I got off a friend when I first bought my car. It does the same thing (but only at small range of throttle positions and engine speeds).
Some of the more better (aka "more expencive") intakes take this into account and/or have better designs so that they don't emit a "musical note" (so to speak). But even some of those will still emit a tone at certain throttle possitions or RPMs. It's just the nature of the beast with no intake resonator.
[Modified by PSU-TEG, 8:58 AM 12/13/2002]
[Modified by PSU-TEG, 8:59 AM 12/13/2002]
[Modified by PSU-TEG, 9:00 AM 12/13/2002]
Old Dec 13, 2002 | 05:02 AM
Hondasaurs's Avatar
Ther is a Flat head screw on your TB. It faces the passsanger side of the car. You can adjust this to make the whistling sound go away if you dont want to hear it.
Old Dec 13, 2002 | 05:08 AM
PSU-TEG's Avatar
Default Re: Intake "squeal" from short ram (ZC_CRX)
Isn't that the Idle Adjustment Screw?
Old Dec 13, 2002 | 11:59 AM
Kamin's Avatar
Default Re: Intake "squeal" from short ram (PSU-TEG)
not really
it angles the butterfly in the throttlebody, but it can change the idle a little bit.
[Modified by Kamin, 12:59 PM 12/13/2002]
Old Dec 13, 2002 | 06:58 PM
SupaTegRS's Avatar
yeah mine only makes the noise very briefly when I press the throttle hard, or realease it quickly.
Honestly, i kinda like the noise
Old Dec 13, 2002 | 07:19 PM
RaceTilIDie's Avatar
You can sometimes change the sound by loosening the clamps an moving the tube closer or farthe from the TBand see if it gets better, then tighten them back down.
Old Dec 13, 2002 | 07:39 PM
tominos's Avatar
Default Re: Intake "squeal" from short ram (RaceTilIDie)
my friends b18c1 with aem cai, does the same thing, then he put in the water stop valve and the noise goes away. i forgot what the piece is called.
Old Dec 13, 2002 | 08:09 PM
Default Re: Intake "squeal" from short ram (tominos)
Bypass valve, or BPV.
Old Dec 13, 2002 | 09:50 PM
MikeMAN's Avatar
Air Bypass valve to be precise hehe
Old Dec 17, 2002 | 04:41 AM
suprajb's Avatar
Default Re: Intake "squeal" from short ram (MikeMAN)
the small flat screw is the idle adjustment,.. it controls a smallamount of air to the aic. it has noting to do with throttle plate position,.. but tampering with that does make the noise go away
Old Dec 17, 2002 | 07:59 AM
Razor's Avatar
Default Re: Intake "squeal" from short ram (suprajb)
most likely you have a crack somewhere in the piping or it isn't clamped correctly to the throttle body. when you have air rushing through a pipe with a hole or crack in the piping itself, it will make the high pitched squeeling noise.
just reinstall it and see if its ok, if not you might have to shell out the money for a quality intake like AEM or iceman.
benson03
Nov 6, 2007 01:26 PM
nk2k2
Jun 14, 2006 02:17 PM
xxintegrlxx
Jun 24, 2005 08:46 PM
GetCaughtDead
Oct 6, 2004 03:07 PM
csfalcon
Jun 12, 2002 03:13 PM
