ZC Motor Swap just completed, not getting fire from the distributor!
Old Dec 12, 2002 | 09:03 PM
Stebo77's Avatar
Default ZC Motor Swap just completed, not getting fire from the distributor!
Need help, I tried starting my '88 DX Hatch with a ZC motor, and it just turns over, won't crank, I used to spark test tool, and i'm not getting any spark from the distributor. Any ideas.
Old Dec 12, 2002 | 10:52 PM
SuperSH's Avatar
Default Re: ZC Motor Swap just completed, not getting fire from the distributor! (Stebo77)
Is there power going to the coil? Is there power coming out of the coil? Which ECU are you using? Is the dist. turning? I would assume it is but you never know. There is not much to the ignition system just track it back to the source your on step two.
Old Dec 13, 2002 | 04:59 AM
Hondasaurs's Avatar
I recently had the same problem with my ZC. My ignitor was bad, its the little rectangle box with the four wires going to it inside the distributer.
Old Dec 13, 2002 | 11:35 AM
Stebo77's Avatar
Default Re: ZC Motor Swap just completed, not getting fire from the distributor! (SuperSH)
I'm not sure what the coil looks like. I'm using the 88-89 Integra ECU. I pulled off the dist. cap, and the rotor is turning. How do i check the coil?
Old Dec 13, 2002 | 11:36 AM
Stebo77's Avatar
Default Re: ZC Motor Swap just completed, not getting fire from the distributor! (ZC_CRX)
Would I have the change my whole distributor to fix this? Or should i just do it anyway to be on the safe side?
Old Dec 13, 2002 | 11:45 AM
Stebo77's Avatar
I read on some wiring diagrams, that you have to modify the wiring to the distributor, i never did any of this because they said it had a round plug, mine has a square plug the just pluged right up. There's only one empty slot, and it's matches with an empty slot on the other plug.
Old Dec 14, 2002 | 10:09 AM
0554's Avatar
hey man dont listen to these fools i can gaurantee you thats it has nothing to do with the distributor. u know where the thermostat housing is right behind the distributor there is a ground right there make sure that is connected. also the main ground right under the battery need to bee hooked up
Old Dec 16, 2002 | 01:10 PM
Stebo77's Avatar
Default Re: ZC Motor Swap just completed, not getting fire from the distributor! (b16a12seccrx)
I checked both of those today, they're both hooked up. I also changed out my distributor, rotor, and cap.
90civic-ZC
20
Oct 29, 2011 07:57 PM
91civicZcSw4p
Jul 22, 2008 01:44 PM
JT2MA71
Apr 5, 2007 10:50 PM
h22_crx
Mar 19, 2006 12:20 PM
