Yoko AVS ES100 vs. Yoko Parada Spec2 vs. Bridgestone RE730
Old Dec 12, 2002 | 04:23 PM
AlexLude's Avatar
Default Yoko AVS ES100 vs. Yoko Parada Spec2 vs. Bridgestone RE730
Hey you guys.. i've heard lots of ppl ranting and raving about the
Yokohama AVS ES100's.. are they pretty good on grip and road noise? I'm running on Yoko Paradas spec1 right now and well they are a bit noisy..
or should I just go get the Bridgestone S-03 pole positions? Any help would be greatly appreciated!!!
Old Dec 12, 2002 | 04:28 PM
DsITR's Avatar
Default Re: Yoko AVS ES100 vs. Yoko Parada Spec2 vs. Bridgestone RE730 (AlexLude)
you might wanna try gettin the Parada spec2...I have those and am really happy w/them...my friend had the spec I and I drove his car around some corners near my house...his tires broke free alot earlier than mine, and the spec 2 is also supposed to have better wet traction.
Im not sure of the AVS, but I think they are more $$ than the Parada.
I need to go to 16" azenis for auto x so I am sellin my yok's for $300 they have less than 6k on them, no camber where..lemme know if you are interested. they are 215/40/17's..check my sig.
Old Dec 12, 2002 | 04:33 PM
AlexLude's Avatar
Default Re: Yoko AVS ES100 vs. Yoko Parada Spec2 vs. Bridgestone RE730 (dsludefosho)
I have the spec 1's and well it seems as if they're pretty noisy... actually go to tirerack.com and check on the AVS ES100.. pretty good reviews and cheaper than the parada spec 2's....
Old Dec 12, 2002 | 07:23 PM
DsITR's Avatar
ohh.. I was thinking of the original AVS or the AVS db I think...the kind they but on benz's I've never seen the Es100 until now.
Old Dec 12, 2002 | 07:24 PM
ZoNe_HKS's Avatar
toyo t1-s =]
Old Dec 12, 2002 | 07:58 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: Yoko AVS ES100 vs. Yoko Parada Spec2 vs. Bridgestone RE730 (PDP_HKS)
Parade Spec 2... great traction in any condition, i will never own any other high performance tire
Old Dec 12, 2002 | 11:05 PM
HondaH22A's Avatar
Bridgestone Potenza RE730 or S-02, they are the best. Don't know about S-03 though, never tried them.
Old Dec 12, 2002 | 11:09 PM
TimeRacer's Avatar
Default Re: Yoko AVS ES100 vs. Yoko Parada Spec2 vs. Bridgestone RE730 (HondaH22A)
Some of you guys have some narrow minds.
I've never stayed with a single tire each time. RE-92, T1-S, RE-730, A520, and next is P-zero. Each tire has different qualities. The best "performance" tire that I've had thus far is the A520's or the T1-S depending on what qualities that you want. The RE-730 (keep in mind this is gen 1) was too hard of a compound and was affected by temperature way too much. Along with the fact that it's transitional handing traits were probably the least predictable other than the RE-92's.
Old Dec 13, 2002 | 06:05 AM
stoopid215's Avatar
im running parada spec2's and they are great.. its hard to lose traction with these tires, they grip so well.
Old Dec 13, 2002 | 06:21 AM
GAperformance's Avatar
New User
Default Re: Yoko AVS ES100 vs. Yoko Parada Spec2 vs. Bridgestone RE730 (stoopid215)
I just put the AVS ES100's on my car. I can't compare them to Parada Spec2's but I had Toyo Prox. on before and the ES100's are far better. They grip better in both wet and dry conditions. I could spin the Toyos all the way through 2nd gear and the ES100's have a slight spin in 1st but still pulling the car along and straight pull in 2nd gear. Keep in mind that on my last dyno I had 232whp and 190tq so traction is an issue with my car.
K20_si
Apr 21, 2011 04:13 PM
usdmEHboy
May 15, 2010 11:51 AM
maxogsr
45
Apr 17, 2007 05:04 PM
wreckedmyteg
Jun 9, 2005 04:22 AM
variable_x
May 10, 2003 12:11 AM
