Questions on old stages Hondata systems
Old Dec 12, 2002 | 10:58 AM
VSM EXtasy's Avatar
Default Questions on old stages Hondata systems
I have a hondata stage 2, i don't need the new features on the new S200 models so i will not be upgrading. Will the stages 1,2,3,4 be obsolete or can the new version of rom editor also work on the older versions of hondata???
Old Dec 12, 2002 | 11:05 AM
PM-Performance's Avatar
Default Re: Questions on old stages Hondata systems (VSM EXtasy)
the rom editor v3 will not work on the odl ones. you have to use the v2.5
im in the asme boat, but i dont think its a big deal . just have access to less maps.
Old Dec 12, 2002 | 11:09 AM
ekb18c's Avatar
It's not a big deal. Most Hondata dealers, like us, will have the v3 and v2.5 software to do either or.
edit - and the stage 4b or the s200
[Modified by ekb18c, 12:10 PM 12/12/2002]
Old Dec 12, 2002 | 11:32 AM
JT's Avatar
JT
Default Re: Questions on old stages Hondata systems (itr206)
The RomEditor v3 should work with the older version of Hondata. However, certain new and improved features are only available when used with the S200.
http://www.hondata.com/romeditorv3.html
Old Dec 12, 2002 | 11:39 AM
Default Re: Questions on old stages Hondata systems (JT)
it wont . i found out from Hondata , becuase i even asked them that .
Old Dec 12, 2002 | 11:43 AM
ekb18c's Avatar
HUH?
If you have the v3 software and you are trying to make a new map.
The first thing it ask you is : v3(s200 or s100) or v2.5(stage 2, 3,4)
From there you go do your thing. So as long as you new software or old software and stage4b then you can still tune the older stage 2,3,4.
Edit - made it less confusing. The new software has a option to select version 3 for s200, s100 or v2.5 for stage 2,3,4.
HTH
[Modified by ekb18c, 1:19 PM 12/12/2002]
Old Dec 12, 2002 | 11:46 AM
Default Re: Questions on old stages Hondata systems (ekb18c)
so with my 4b i can still use the V3 and all the new maps that aer on it ?
are you sure on this?
they aid no when i asked them
they said the only way i could use v3 is if i had s200 or s100 with the rom editor option on it
orif i upgraded mine .
now they said you can have a s100-s200 and tune stage 2-3-4, but the 2-3-4 cant tune s100-s200
Old Dec 12, 2002 | 12:15 PM
ekb18c's Avatar
ok your getting it mixed up here.
v3 software - will work for s200, s100
V2.5 software - stage 2,3,4
However with the new software from Hondata you can select either v3 or v2.5.
With the stage 4b you have to be on v2.5.
S200(dealer version) can only tune s200 and s100 as far as i know.
Stage 4b can only tune stage 2,3,4.
edit- I see what I said, that might have confused you. Sorry.
[Modified by ekb18c, 1:17 PM 12/12/2002]
Old Dec 12, 2002 | 12:18 PM
thats exactly what i just said ,thanks .
Old Dec 12, 2002 | 12:20 PM
ekb18c's Avatar
iBrandon
Apr 18, 2005 07:33 AM
civic-97-si-nx
Dec 9, 2004 12:35 PM
hondamanwill
Jan 4, 2004 07:10 AM
BLaCKWiDoWSi
Nov 2, 2001 08:14 AM
