Rockford Fosgate amps
Old Dec 11, 2002 | 09:03 PM
Ronin Integra8's Avatar
Default Rockford Fosgate amps
someone mentioned to me awhile back ago, that if you have two rockford amps, there is something that you can buy and connect the two together and you have like double to triple the amount of power from the amps. Does anyone know what I'm talkin bout? Where can i find it? And how much would it run about? this is the older model amp like about 2 yrs go, not the most recent one
Old Dec 11, 2002 | 10:10 PM
101998's Avatar
Default Re: Rockford Fosgate amps (Ronin Integra8)
the older one you will prob have to call fosgate. most places will only stock the newer style.
Old Dec 12, 2002 | 04:23 AM
o_Rage_o's Avatar
Default Re: Rockford Fosgate amps (audiobahnman)
i don't know if you can do those on the older amps, but there is a thing called BDSYNC in which you can take the ouput of two bd class amps and basically add them together; I can't see it tripling output, but it will sum up both amps to a certain amount to one or two drivers.
-Rage
Oh yea, it should only be the cost of the cable to do it..its basically like bridging a 4 channel amp, but your "bridging" across 2 different amps
[Modified by o_Rage_o, 8:23 AM 12/12/2002]
sumdewd
Audio / Security / Video
May 17, 2012 05:22 PM
ej1type-r
Sep 8, 2011 07:22 AM
89hbcivicguy
Mar 3, 2005 09:12 AM
freeplay
Dec 17, 2002 08:42 PM
freeplay
Dec 15, 2002 11:25 PM
