Honda S2000 Honda S2000
What is the top speed (stock) of the S2000?
Old Dec 11, 2002 | 08:21 PM
Yellow Dragon's Avatar
Default What is the top speed (stock) of the S2000?
Thanks.
-Todd
Old Dec 12, 2002 | 05:00 AM
Track rat's Avatar
Default Re: What is the top speed (stock) of the S2000? (Yellow Dragon)
Over on S2ki.com, several guys had made runs around 155 - 160.
Old Dec 12, 2002 | 06:05 AM
blacks2000's Avatar
Default Re: What is the top speed (Track rat)
There's a video around that shows someone going like 270 km/h. I think at redline in sixth, and under IDEAL conditions, it tops out at like 170 mph.
Old Dec 12, 2002 | 07:11 AM
blacks2000's Avatar
Default Re: What is the top speed (c steve)
I think I read that he was turbo.....it's a crazy video
Old Dec 12, 2002 | 11:45 AM
jerrypeterson's Avatar
Default Re: What is the top speed (blacks2000)
I think TurboDave was going downhill in a stock S2000.
Old Dec 12, 2002 | 01:05 PM
Thanks everyone. I thought they'd have a higher top speed. Are they limited?
Old Dec 12, 2002 | 02:01 PM
Chris N's Avatar
Default Re: What is the top speed (Yellow Dragon)
Can't we just figure it out mathematically using the gear ratios??
Old Dec 12, 2002 | 05:09 PM
blacks2000's Avatar
Default Re: What is the top speed (Chris N)
It's been done. At redline in sixth, you'd be at like 170 mph.
Old Dec 12, 2002 | 06:17 PM
gastonS2k's Avatar
realistically it's about 150 - 155 drag limited, not redline limited.
Old Dec 13, 2002 | 03:12 AM
:jdmshmaydm:'s Avatar
OT: c steve your avatar cracks me up.
Old Dec 13, 2002 | 07:44 AM
D-Style's Avatar
Usual reports are anywhere around 145 to 155 top-up... It's aerodynamically-limited. Top down, I dunno what the top speed would be, maybe 140.
Old Dec 14, 2002 | 10:57 PM
Moyopoyo's Avatar
New User
Default Re: What is the top speed (D-Style)
147 - top down
156 - top up
one of the local s2ki members has told me he's done both of these.
Old Dec 14, 2002 | 10:58 PM
Brasspremier's Avatar
Default Re: What is the top speed (Moyopoyo)
wow, i had no idea they went THAT fast.
Old Dec 15, 2002 | 06:27 PM
profpin's Avatar
Default Re: What is the top speed (Brasspremier)
I went 158 mph with the top up......
All motor All stock.........
I really dont recommend going that fast thought........
You deffinitly need a long strech of road to do it........
Old Dec 21, 2002 | 08:40 PM
MOCrxHf's Avatar
Default Re: What is the top speed (profpin)
On interstate 70 between on the way back from St. Louis when my friend bought his we did 158 downhill top down between 2 semi's. Scary ****. I'll never do it again. BTW, yes, same guy that blew up 3 motors.
Old Dec 21, 2002 | 08:52 PM
sslude's Avatar
Default Re: What is the top speed (MOCrxHf)
that is so crazy.
Old Dec 25, 2002 | 01:16 PM
StormBringer's Avatar
Default Re: What is the top speed (sslude)
Top speed in a S2000 completely stock is 164 mph GPS tested by myself, the fastest I have ever gotten the car to go with the top down is 154 again GPS and I had a very long stretch of road to test absolute top.
The gearing will only allow for the car to go to about 168 as far as I know, but as I understand it you hit the aero wall and gearing wall at the same time. I believe that you can get a higher recording using the stock speedo then 164 but I would attribute it to calibration then to differences inbetween cars.
Now having said that said that no matter how much power you put into the car you still have the same top speed you simply get there a lot faster, as above 140 the car starts to slow down quite a bit specifically with the top down. But if you were able to squeeze a bit more rpm out of the moter then who knows what is possible. Really I don't want to find out, the car has amazing stability above 130 but man you don't want to be doing it in a crowded place.
Old Dec 26, 2002 | 08:59 AM
Moyopoyo's Avatar
New User
Default Re: What is the top speed (StormBringer)
wesmaster - 169
turbodave - 170+
edit: you've obviously never read/seen any of the posts by people with forced induction on s2ki.
[Modified by Moyopoyo, 12:02 PM 12/26/2002]
Old Dec 26, 2002 | 09:09 AM
And you did not read the part about the GPS testing. I have never seen anybody post other then myself on how they came to that speed. I personally have seen 169 on the speedo on my stock car but I do not say that is the top speed as it simply was not so when we calculated it using the distance with the GPS.
Mathmatically I understand the top speed to be 164-165 as far as gearing goes.
Two as I understand it Wes has the 4.44 gears he sure as heck is not getting anywhere close to 160, unless he did this prior to installing them
Old Dec 26, 2002 | 09:23 AM
Moyopoyo's Avatar
New User
this is the part i was trying to quote from you.
the car will only be able to go so fast on the stock motor. once you upgrade (forced induction being the highest form), you can go faster than you could before.
wes does own a 4.44 final gear, but it's not installed right now.
all i'm saying is that the part i quoted from you above is very wrong...so i obviously did read your post correctly (again)
Old Dec 26, 2002 | 09:17 PM
Not that I want to continue to argue but define faster. If it is reference to top speed then no mater how much power you have you will never be able to go faster IE top speed then a stock car. Unlike most cars S2000's are not computer or drag limited, they can run to the end of the gearing. Since this is not changed with the increase in power the car simply can not have a faster top speed.
But I digress, if you mean faster as in acceleration then yes more power will make you go faster Dduhhh.
Old Dec 27, 2002 | 02:21 AM
Moyopoyo's Avatar
New User
i mean faster as in top speed.
i talked to wes before i posted last, and he told me i was right. i wouldn't just throw stuff i didn't know about in your face.
do you understand what i'm talking about when i say that the stock s2000 can only go 155 +/- (a few), and a s2000 with forced induction can go upwards of 170?
Old Dec 27, 2002 | 05:10 AM
Red*EG*'s Avatar
Default Re: What is the top speed (Gatecrasher18AF)
I think the top speed is about 150MPH.
Old Dec 27, 2002 | 11:45 AM
Dave421's Avatar
If a car is drag limited, power output WILL change it's top speed. Once the car has the extra power needed to "break" through the aerodynamic wall, it will. top speed is an equation of power, drag coefficient (wind resistance), gearing, and resistance (tires resistance on the ground do not go into a drag coefficient). Change one factor and top speed changes.
If a car is redline limited, the top speed will not change no matter how much power you add UNLESS the power is added by raising the redline (along w/ headwork/cams, etc.) In order to increase top speed of a redline limited vehicle, you must change the gearing (top gear ratio, final drive, or tire size) OR a raised redline (not too common on a 9000rpm S2000).
(edited for dumbass remarks)
[Modified by Dave421, 8:45 PM 12/27/2002]
[Modified by Dave421, 2:57 PM 12/28/2002]
Old Dec 27, 2002 | 07:58 PM
Moyopoyo's Avatar
New User
Default Re: What is the top speed (Dave421)
he said that the car won't get a higher speed no matter what you do. the car stock, can only get to 155 (8,000 rpm) in sixth gear. the car can go faster than that. i didn't ever say that the car stock can hit the redline in sixth gear, 'cause it can't.
