Comptech swaybar adjustments= soft(14mm)medium(19mm)stiff(22mm) or what?
Has anyone ever said it this way? For those who have one, what do you think it would be equal to at each setting? This seems to be the only forum for this topic since I'll be using it for autoX. Thanks
well i can't really put it into individual mm numbers but the middle setting is the same stiffness as the original non-adjustable bars so i would start with 22mm for the middle setting if you are going to try and figure out values for each. Thats also the same setting that SSC cars are required to run.
[Modified by ryan12321, 12:15 AM 12/12/2002]
Comptech claims that the middle hole is comparable to an ITR 22mm bar, with the three adjustment holes making an incremental 5% difference.
So...
Medium = 22mm and soft and hard should equate to less than 1mm difference.
[edit] yea, what he said...
[Modified by JeffS, 12:22 AM 12/12/2002]
So...
So, would I really be able to tell a difference between the settings if they're only equal to 1mm?
It's doubtful. I've only ever run on the stiffest setting.
I'm too lazy to do the math, but 5% is very minimal as far as swaybars go. It's only good for fine-tuning.
