FS: GSR Swaybar, Control Arms, and B-Series Transmission Parts
Both parts are off my 01 GSR. The swaybar was taken off around 12k miles, and the control arms at 20k.
Here are the control arms. I have no need for them, I went with Skunk2 Arms. They are not bent, and in mint condition. The ball joints are also in mint condition.
$75 Shipped
Here is the sway bar. It is 14mm and will be a great upgrade to a car without a swaybar stock. It comes with stock brackets, bushings, bolts and stock mounting hardware. I have no use because I upgraded to an ITR sway bar.
$55 Shipped --- SOLD
USDM ITR 5th Gear- $60 shipped
USDM ITR 1st Gear(includes needle bearings)- $40 shipped
USDM ITR 4.4 FD Ring Gear- $40 shipped
1998 GSR Clutch Fork- $15 shipped
2001 GSR Block/Trans Braces- $25 shipped
1998 GSR Intermediate Shaft- $100 shipped
2000 B16 VSS- $35 shipped
I am open to trades, so tell me what you have. If you are local, you can pickup and I will drop the price
[Modified by Big Teggie, 4:57 PM 12/16/2002]
$75 Shipped
You don't happen to have the LCA from a GSR or Type R do yah? Just a quick question, in order to make those sway bars to work on an EG si, you need the LCA right?
Thanks man.
Thanks man.
The sway bar is sold. Yes, You would need Integra lca's. I also heard you can get them from some 4dr civic that has a swaybar stock.
stevieteg
Jan 10, 2004 12:33 PM
Big Teggie
Apr 5, 2003 12:40 PM
