Price to install factory foglights?
i have a 00 Si and a friend of mine was gonna hook me up with some OEM foglights and i was wondering if anyone has an idea of what a decent body shop would charge to install and wire them in? i've seen on jdmfan.com on how to do it, but i don't trust myself cutting holes in my bumper.
i got done mine at $100 in local shop... like you said, i couldn't trust myself cutting out holes..
i'm guess it depends on where you live,too. some places charge more, some places charge less i guess...
got mine done at the dealership for $75. But thats cause I have a friend that works there. Just open up the yellow pages and make a few calls cause every place will have a different price.
cut out a couple pieces of cardboard to replicate the foglight covers then outline it on the front bumper, very easy, took me a couple of hours to cut it out.
See!!!
See!!!
It's an easy job...The instructions tell you to use a hole-saw attachment of a certain size to do a majority of it, but you can just preforate the preset lines for the foglights by using a small drill bit. Drill holes along the line as close together as possible, then use a box cutter to connect to dots. As long as you don't go way off the lines you'll be fine because the trim piece will cover it up. I say save your money by DIY, and spend it on some PIAA ION gold H3 bulbs for the fogs...Good Luck!
Quik
Trust me you can do it your self.
I took mine to the honda dealership and they charged me $180 F*cking Dollars
It's dummy proof, I realized that after I got mine installed.
Just pull the bumper off & check out the inside of it. It shows you where you need to cut it. If you feel that you can't do it, then pay some one, but at least take a look first. When it comes to the wiring, just follow the directions. It's just plug in & your ready to go...
Here is my
Full Size
http://members14.clubphoto.com/_cgi-...69-e049&trans=
[Modified by Lexor_00Si, 3:56 PM 12/12/2002]
Here is my
Full Size
PM-Performance
Oct 22, 2003 08:10 AM
