150-200 direct shot d16?
Old Dec 11, 2002 | 09:32 AM
td04civic's Avatar
Default 150-200 direct shot d16?
I'm building a d16 w/ wisco 9:1 pistons and eagle rods w/ a block guard.
With correct fuel and tuning how much nitros can it handle w/ race gas of course.
The setup will be a direct port system from NOS.
And is a VAFC good enough to tune the car or sould i go hondata stage 2.
I'm looking for around 300 whp for the d16z6. Thanks alot.
Old Dec 11, 2002 | 09:36 AM
PM-Performance's Avatar
Default Re: 150-200 direct shot d16? (td04civic)
your ****** nutts dude.
good luck /
the vafc should be fine , i had mine tuned with the vafc.
wow. . . . elt us know how it goes
Old Dec 11, 2002 | 10:00 AM
vtecvoodoo's Avatar
Future Texas Boy
You should sleeve it.
Sidenote: I ran a 100 shot on a d16 years ago. It lasted about a year, but I only went through a bottle every other month or so.
Ryan
Old Dec 11, 2002 | 10:03 AM
Default Re: 150-200 direct shot d16? (vtecvoodoo)
i did 100 shot on my car, but 150-200+ , take proper precautions
Old Dec 11, 2002 | 10:16 AM
td04civic's Avatar
Default Re: 150-200 direct shot d16? (itr206)
so w/ the pistons,rods,blockguard and correct tuning do you think the d16 could handle 300whp on race gas?
Old Dec 11, 2002 | 10:52 AM
*Boostwerks*'s Avatar
maaaaayyyyyybbbbbeeeee.
Why don't you find out....
Old Dec 11, 2002 | 11:00 AM
turbopanda's Avatar
Default Re: 150-200 direct shot d16? (Bryson)
lol good luck dude
Old Dec 12, 2002 | 07:01 PM
td04civic's Avatar
Default Re: 150-200 direct shot d16? (turbopanda)
Whats the best compression for a d16z6 running 150shot on race gas?
Old Dec 12, 2002 | 08:06 PM
tony1's Avatar
Just thought it was funny to see "nitros". Kinda like a redneck...."hey boa, how much nitros you got on that sum bitch..."
Old Dec 12, 2002 | 08:25 PM
BudaKai's Avatar
I've seen crazy stuff like that before. What you should do is sleeve it; get the pistons and rods, then build up your valvetrain to handle the aggresive nature of nitrous oxes. Pick your clutch very wisely in comparison to how your going to run it. Do yourself a favor and take it easy on the intake and such. If you go too crazy you'll easily over-rev, or fry your motor. You don't need air-flow with nitrous that's the common mistake everyone makes. I learned the hard way on that one. Nitrous is an oxidizer so you can run a big tank with a smother type manifold, and make huge power. You just make sure the block can handle it. Especially the bearings.
Old Dec 12, 2002 | 09:02 PM
MiraiZ's Avatar
Default Re: 150-200 direct shot d16? (tzsir)
you'll blow the welds on your intake dude
Old Dec 12, 2002 | 09:07 PM
rOby's Avatar
Default Re: 150-200 direct shot d16? (MiraiZ)
well first off u will need to build ur block. sleeves, rods and pistons. ur head WILL need to be built as well. atleast the springs need to be upgraded. a progressive control is a must..and a prayer..im me and ill see if i can help ya get parts..i want to see this.
roby
Old Dec 12, 2002 | 09:14 PM
Mr. Softee's Avatar
Default Re: 150-200 direct shot d16? (roby)
nitrous isnt for amateurs
brian?
Dameltajo
May 7, 2006 10:40 PM
ebp_dc2
Mar 18, 2005 02:18 PM
nevin
Feb 5, 2004 07:44 AM
3700 Vtec
Dec 15, 2002 10:36 AM
gsl_05
Aug 13, 2002 06:24 PM
