does anyone know who makes a slimfan for the 5th gen?
I'm wondering too. I need them for both the ac and radiator fan. BTW, how much did you pay for your custom downpipe?
Guest
Posts: n/a
i don't know what this price is yet, b/c they are in the process of fabbing my IC piping right now as well, i should get a break down of the price in a day or 2
http://store.summitracing.com/partdetail.asp?part=24928
use those. might have to make a bracket not sure.. im gettin those.
i eleminated my a/c relay a long time ago, it went out about the same time my temp switch went out. my fans are now wired on the ign. switch. key on, fans on, helps keep it cool. plus when you at the track, you can run the fans to cool things down between races, w/out running the car
SPAL slimline fans. Only 1.12" or 1.08" high, can't remember which one.
I made a wire connector so I can connect the fans to the stock connectors. I also used the Spal pin mounting kit, which uses pins that run through the radiator to mount the fans. The fans were like $65 a piece.
[Modified by Quaalude, 12:32 AM 12/12/2002]
avex
Apr 22, 2004 09:27 PM
