ecu from a 93 gsr will it work with 95 gsr
i know they r both differnt motors but theyre not dat different will i be able to use the Gsr ecu('93) on a '95 gsr motor??....is the '93 and '95 ecu similar??...thanks
You do know that the 90-91 teg ECU's plug into are cars (4th gen HB's) 92-93 use OBD1 plugs witch will not plug into are ECU plugs. Unless you do a plug swap or get an adapter kit. Also make sure the distributor is the same year as the ECU. Or just a get a Zdyne if you if the money.
