Wheels/Control Arms...how much clearance is safe?
After finally getting tires for these bad boys, I decided to test fit the panasports to the CRX just to tripple check before I mount the tires. I only looked at the rears (more to make sure it was the right bolt pattern and to test the fitment of the lug nuts I hope to use). There is VERY little clearance between the wheel and the upper control arm, but the wheel spins freely and there is nothing touching or rubbing for sure. I suspect the fronts will have even more clearance, since I only hear about problems in the rear. My question is, is "just barely enough clearance" enough clearance? Is there any flex or movement that I need to check before I take these up to speed?
Sounds dangerous to me. Please ship me your wheels and I'll evaluate them for a year or so.
Jerry - Who's always willing to go in harm's way to help a fellow CRXer.
My inexperience with very wide wheels is showing. Anyone else care to comment? I have NO problem running spacers, I just don't want to if I don't have to, and they might create tire clearance issues on the other side of the wheel. Paranoia?
-travis, who had his panasports ready for shipping to Geezer, but thought better of putting him in harm's way.
your 38 offset panasports should be fine on a crx. you should massage the fender lips both front and back tho. plastic rubbing will be fine, but you dont want the fender to cut into the tire.
[Modified by travis, 3:16 PM 12/11/2002]
killahatch
17
Jul 6, 2010 07:05 PM
Tractor_Boy
Aug 6, 2009 11:47 AM
sshaikh01
Mar 24, 2003 01:31 PM
CWESTINAP1
Mar 8, 2003 11:23 AM
