95 Accord Lx Coupe With H22A
Old Dec 10, 2002 | 08:55 PM
ricepicker's Avatar
Default 95 Accord Lx Coupe With H22A
I just recently did the swap about 4 months ago. The only problem I have had from day one is when. I am driving along and I put it in neutral to coast. While I am coasting my motor idles at about 1500 RPm. When I come to a complete stop, the RPM falls and idles normal at about 700. Would anyone happen to know what causes this?
Old Dec 10, 2002 | 09:08 PM
WhoNeedsVtec's Avatar
Default Re: 95 Accord Lx Coupe With H22A (ricepicker)
dont coast in neutral it is bad for the engine/tranny
Old Dec 10, 2002 | 11:12 PM
Razor's Avatar
Default Re: 95 Accord Lx Coupe With H22A (WhoNeedsVtec)
Old Dec 11, 2002 | 05:25 AM
KGAccord's Avatar
I'm not going to downshift through 5 gears every time I stop, that causes wear too.
Now coasting down a hill my be stupid idea though.
Old Dec 11, 2002 | 05:37 AM
urbanlegend21's Avatar
New User
Default Re: 95 Accord Lx Coupe With H22A (KGAccord)
do you have the old F22 tranny?
Old Dec 11, 2002 | 06:51 AM
b18bEG's Avatar
that same thing happed to me, the roblemn is that some of your vacum hoses are not attaced properly, and there is a leak some where. find the hose and there is your problem
Old Dec 11, 2002 | 08:28 AM
m0t0rhead's Avatar
What ??? That's a crock.
Old Dec 11, 2002 | 09:21 AM
Charlie Moua's Avatar
Default Re: 95 Accord Lx Coupe With H22A (Escobar)
that's BS. please stop posting incorrect info/ facts.
Old Dec 11, 2002 | 09:24 AM
Nick M's Avatar
Coasting in neutral is dangerous, if you have to make an emergency manuever you have to put the car in gear to respond etc.
Its not bad for the engine or tranny. In neutral the car is not in gear therefore the clutch is not engaged so there is no power going through the transmission. Idling is a complicated thing for a modern engine to do, maintaining a certain rpm by reading various sensors and vacuum. Letting a car idle for long periods of time isnt necessarily good for it, but it wont really affect engine life unless its allowed to idle for long periods of time over many years.
Old Dec 11, 2002 | 11:55 AM
[QUOTE]I'm not going to downshift through 5 gears every time I stop, that causes wear too.[\QUOTE]
buy an auto then
Old Dec 11, 2002 | 12:42 PM
GZERO's Avatar
this might not be the case, but sometimes when the engine gets lots of cold air does this, my accord doesn't do it, but my old car used to do it, if i let it on neutral on a downhill going at about 60 MPH or some highway speed it would do this. Am i making any sense?
Old Dec 11, 2002 | 07:46 PM
Gangsta Accord's Avatar
if it runs normal but that is da only problem den its just your throttle cable stuck jes tap da gas pedal once and it will drop down. and if it keeps on continuing then jes lube up da throttle cable a lil.
Old Dec 11, 2002 | 10:53 PM
ricepicker's Avatar
Default Re: 95 Accord Lx Coupe With H22A (SRMlimited)
its a vacuum problem somewhere. thats all
Even if it idles normal when it is just sitting there?
Is there any place I could find a decent vacuum diagram?
[Modified by ricepicker, 8:07 AM 12/12/2002]
Old Dec 12, 2002 | 04:07 AM
GZERO's Avatar
Hit me up on AIM or IM me, i have a PDF file that has a great vacuum diagram and it has 20 pages of info on the H22A, i try to hosting, but i can't, so let me know so we can figure a way that you can get the file.
Old Dec 14, 2002 | 02:01 PM
WhoNose's Avatar
Default Re: 95 Accord Lx Coupe With H22A (GZERO)
GZERO, could you possibly e-mail me that diagram also?
2171USMC
Jun 26, 2018 01:21 PM
JDM H power
Apr 27, 2006 06:25 PM
L_K
Sep 30, 2004 05:00 PM
EG8R
Oct 14, 2001 06:17 PM
