2000 GSR or 2000 ITR cams for turbo?????
Old Dec 10, 2002 | 08:22 PM
Turbo R's Avatar
Default 2000 GSR or 2000 ITR cams for turbo?????
which cams would be the most successful when achieving maximum WHP?
Old Dec 11, 2002 | 05:52 AM
00ITR #543's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (NA ITR)
wondering the same thing. I have heard many different things. I am considering GSR cams. TURBOTYPER said he made 100+ more hp with the GSR cams...
Old Dec 11, 2002 | 06:08 AM
DC2R714's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (00ITR #543)
Skunk2 Turbo cams
Old Dec 11, 2002 | 06:14 AM
PM-Performance's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (DC2R714)
there is someone in here making like 400 whp or so on stock type r cams .
who acn bakc up this 100+ hp with GSr cams? ill buy some in a heartbeat if thats actually true
Old Dec 11, 2002 | 06:17 AM
00ITR #543's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (itr206)
turbotyper is the guy with the dyno numbers. That would be GSR cams in an ITR head...
Old Dec 11, 2002 | 06:21 AM
BoM's Avatar
BoM
u can sell ur itr cams to buy gsr cams w/ new valvetrain.
it has always performed better for turbo applications.
Old Dec 11, 2002 | 06:28 AM
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (BoM)
i wanna see dyno plot cuz that sounds like too much hp for that little change . and no i wouldnt slel my R cams, i can pick up GSR cams for prob close to nothing
what about b16 cams? i have a set of b16a2 cams sitting at my garage right now in a head thats never gonna get used.
Old Dec 11, 2002 | 11:49 AM
Turbo R's Avatar
need more info
Old Dec 11, 2002 | 11:56 AM
TurboITR's Avatar
i have seen 700whp extracted from stock itr cams...
Old Dec 11, 2002 | 11:59 AM
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (TurboITR)
YEA , thats what IM talking about .
Old Dec 23, 2002 | 02:07 PM
DefiantGSR's Avatar
isn't gsr cams the same as b16a2 cams? correct me if im wrong
Old Dec 23, 2002 | 02:41 PM
biassj's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (DefiantGSR)
No GSR has higher lift and duration
Old Dec 23, 2002 | 02:56 PM
avividmemory's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (biassj)
what would be better in a b16 head w/ ferrea train...gsr cams/itr's or skunk2's?
Old Dec 23, 2002 | 05:21 PM
tony1's Avatar
I have seen 900+whp extracted from stock GSR cams!
Old Dec 23, 2002 | 05:55 PM
V-SPEC 1's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (tony1)
Wow!!! and that.................... is what I'm talking about.
Old Dec 23, 2002 | 07:00 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (boostedb20vtec)
my car made 434 whp & 264 torque with itr cams.it made 440 whp and 304 torque with gsr cams.the biggest difference was that at 6250rpm with the itr cams it was at about 300 hp.at 6250 with gsr cams it was at about 438-440hp.the car went from mid 12 second time slips to very traction limited high 11's instantly.i will post the dyno charts tommorow.
Old Dec 23, 2002 | 07:18 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
and there you have it...
Old Dec 23, 2002 | 09:00 PM
TurboITR's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (SIXTYdashONE)
yeah but he is a real racer - with a decent motor able to make 900whp on meth - im just a little street ricer
for the power though tony
but
honestly - i think you will be happy with either cam if you have R cams use them - if you have gsr's use them
if you dont have either - pickup some gsr cams - they are probably cheaper to get used and seem to make more power
[Modified by TurboITR, 1:03 AM 12/24/2002]
Old Dec 23, 2002 | 09:17 PM
tony1's Avatar
Real racer or not, a motor's a motor. Even more so for a street car, go with the gsr's. The type R may make a few more up top but your powerband will be much better with the gsr's.
Old Dec 23, 2002 | 09:19 PM
TurboITR's Avatar
said the guru...
i stand corrected
[Modified by TurboITR, 1:20 AM 12/24/2002]
Old Mar 3, 2003 | 06:35 PM
LonelyDriver02's Avatar
Wow, this is great. Thanks for the advice guys. I have a turbo b16 and was gonna get itr cams cuz i heard they make more power, but now i can get the gsr for even better power and save around $300!
Old Mar 3, 2003 | 06:38 PM
vtecpwred's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (LonelyDriver02)
GS-R cams are better for turbo the ITR cams have something to do with the overlap not so good GS-R performs better.
Old Mar 3, 2003 | 06:47 PM
M-Type's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (vtecpwred)
You want GSR cams, The ITR have too much lift and is more built for NA.
Old Mar 3, 2003 | 06:48 PM
boosted hybrid's Avatar
The stock itr cams can have the duration and lobe center altered in a manner they would be the best turbo cam you can get OEM. I am having a set of ctr cams modified to gsr duration specs to give the best of both worlds (lower duration, higher lift).
Old Mar 3, 2003 | 06:54 PM
Soon_2b_evil's Avatar
Default Re: 2000 GSR or 2000 ITR cams for turbo????? (boosted hybrid)
I know this is off the subject but i also heard that the CTR cams were better then the ITR cams cuz its got +2dregress on the ITRcams. something like that
