how much boost are you SOHC turbo guys runnin?
Old Dec 10, 2002 | 06:57 PM
Boostless97Lude
Guest
Posts: n/a
Default how much boost are you SOHC turbo guys runnin?
i am trying to talk my friend with a del Sol Si into putting a GReddy turbo kit on his stock engine rather than trying to put a swap together (it's official, i'm a boost junkie), but he wasn't impresed with one of the turbo SOHC cars we saw at NOPI on the dyno, it put out 153whp at 6psi, but i told him that their are guys with B16s and such running 12 psi with the VAFC hack on stock engines, and i was just wondering if that was possible with a D16
Old Dec 10, 2002 | 07:04 PM
CzanSOHC's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (Boosted97Lude)
The d16 can take plenty of boost, as long as the timing is retarded, colder plugs, and decent tuning. 12psi w/ a stock block is no problem, and that should be around 200hp or more or less depending on a BUNCH varibles.
swrdply400mrelay's Avatar
Maybe not 12psi daily. I drive with the GReddy kit with 5.5psi daily and 8psi on high boost with the Profec. If he's staying with stock bottom end, do the VAFC hack bc the stock injectors and FMU are only good until 8psi before the fuel cuts off. Also torque with a turbo will be a lot more than an N/A car. With the AFC hack he can run up to 12psi, vtccivic used to and ran low 14's with 100mph traps. Just run about 6-7psi daily and 12psi at the track. D16 rods are toothpicks!
Also top end may not be great with a GReddy kit, but it spools up fast. He can always open up top end with a 3" dp and exhaust.
Old Dec 10, 2002 | 07:24 PM
CzanSOHC's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (swrdply400mrelay)
I know guys that run 12 psi daily. I seen the d16 take 15 psi on a stock block at the track, i'm not saying it's smart, nor do i do it, but d16 can take some boost, and yes, the rods are tooth pics, tend to break around 225-230 whp.
Old Dec 10, 2002 | 07:30 PM
kamaleon's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (CzanSOHC)
im running 5.5.. ill increase it once every bug is taken cared of.
will be 6psi daily and 8psi to have fun. stock hx
Old Dec 10, 2002 | 07:52 PM
yellowsub's Avatar
https://honda-tech.com/zerothread?id=328247&page=1
Old Dec 10, 2002 | 07:55 PM
First Gen Man's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (kamaleon)
i have been running 5-6 daily and 10 psi at the street races... it is taken it fine so far... i have only a fmu and a custom maped ecu.... on a d15b7 10 psi......
Old Dec 10, 2002 | 08:06 PM
98civicEX's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (First Gen Man)
VTC_boostless_Civic ran 12 psi for about a year, daily driver
I did it for about 4 months, w/ no problems...the d16 is a pretty strong motor, you guys who are scared to turn up the boost will be pretty surprised. just step it up slowly by slowly, and before you know it, 12psi is in your reach...TUNING is KEY. i was on VAFC hack btw.
Old Dec 10, 2002 | 08:07 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: how much boost are you SOHC turbo guys runnin? (yellowsub)
hahaha... whoops, i never thought to search "d-series"
Old Dec 10, 2002 | 08:49 PM
kamaleon's Avatar
using vafc with boost control on odb2 is equivalent as using hondata on odb1?
im a bit confused as yunning wise to achieve hirger boost with lower risks.
Old Dec 10, 2002 | 10:54 PM
sporkcrx's Avatar
I'm running 5-6 psi right now, by the end of the month it'll be 10.
Old Dec 11, 2002 | 09:22 AM
WhiteSTi's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (sporkcrx)
10 psi right now, but by the end of the year i'll be 15+
Old Dec 11, 2002 | 09:30 AM
rjardy's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (BoostedEX)
for all of a week
Rob
Old Dec 11, 2002 | 09:42 AM
VTC_CiViC's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (rjardy)
liam has boosted 15-16psi in his many D16's, never failed because of overboost (oil starvation and a blown vacuum line oWned his motors )
I think MattT3/T4 has boosted over 1bar regularly on a SOHC as well. Me personally I limited it at 12psi for the occasional race, granted I was very good to my car, didn't live in boost and wouldn't see more than 6psi for daily duties.
It's one thing to ask "how much can a motor handle?" and another to ask "how much can a motor handle every single day", in which case I'd keep the D16 limited to roughly 8psi if you want it to last a long time.
Mine was boosted for 35k miles (1 year) and upon taking it off, my compression is still 190-195-190-195
Old Dec 11, 2002 | 05:20 PM
WhiteSTi's Avatar
for all of a week
Rob
Maybe on stock rods and pistons, but not by block
Old Feb 14, 2003 | 11:39 AM
kHoA DoGG's Avatar
DAMN!!! a d16 can take 8psi daily?!?! STOCK?!?! man, i was aiming for 5.5 internal wastegate. now i'm happy i sold my B16swap for a D16 and piece by piece turbo kit. what is the vafc hack by the way? i have one laying around i can use..
Old Feb 14, 2003 | 12:11 PM
Drew Peacock's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (VTC_boost-less_CiViC)
Yep 8psi here daily for over a year 11psi on race gas very occasionally.. No problems with the engine damn clutch's are beginning to **** me off though
Old Feb 14, 2003 | 12:14 PM
ykracing's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (turbozxi)
I ran about 9 psi daily... on my d16z6...
I dyno'ed at 211whp on a mustang dyno.... then I abandoned the d-series stuff...
Old Feb 14, 2003 | 12:21 PM
Smashback's Avatar
Ditto...blew my ACT clutch before I had a chance to blow the motor. 9 PSI daily and 15 PSI once on accident stock D16Y7 block.
206hp/184tq
To get those numbers with a Greddy you'll need to run a little more from what I've seen, mine was a T3/T04B....thought it was an E but turned out to be a B, now I have to buy a new turbo for the new motor
Old Feb 14, 2003 | 12:22 PM
*Boostwerks*'s Avatar
I have been running 12psi daily for the past YEAR on my stock ZC (9.5CR). They can take it. They just need to be tuned properly, and maintained.
I had to garge it now because the trannies input bearing is shot. Motor however is still in great shape....
Old Feb 14, 2003 | 12:30 PM
dynomax27's Avatar
I've got a d16z6 and im around 8psi. Im on the afc hack, and the engine holds up fine. I beat the car about two times a week for about 2 months now and it's still fine. The only thing is the stock clutch goes by pretty fast.
Old Feb 14, 2003 | 04:53 PM
M.A.R.C.'s Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (dynomax27)
20psi...
hehehe VTC knows what I'm talking about hehehehe
i run 8psi now. made like 165whp @ like 5.5psi on a T3 60 trim
Old Feb 14, 2003 | 05:07 PM
turbod16y8's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (CivicRyda2k)
5-6 psi daily on mine for a year already. still strong. take it up to redline 4-5 times a week. was running 12:1 fmu and intank. tuned using my nose as a sniffer.
Old Feb 14, 2003 | 06:14 PM
BoostedED9's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (turbod16y8)
my car has been set at 14 for hte past 2 months..... stock 160k+mile internals just a head gasket and arp headstuds... look at sig for dyno #'s.. i dont know of anyone else that has hit my #'s on stock internals yet, does anyone else know of anybody that has?
Old Feb 14, 2003 | 06:21 PM
GOLDBERG's Avatar
Default Re: how much boost are you SOHC turbo guys runnin? (BoostedED9)
boosted them some dang nice #'s..i didnt even know our d series engines could handle 14psi daily
i'll be boostin 9 or 10 by the end of the week, hopefully
