is this where the oil squirters go (h23 block)
Old Dec 10, 2002 | 06:41 PM
BoostedH23a1's Avatar
Default is this where the oil squirters go (h23 block)
when i build my motor im gonna get some vtec oil squirters. just wondering if this is the right spot..
im talkin about the one on the right. the number 1 and number 4 cylinders both have the 3 holes but all of them have that 1 like on the right..
[Modified by BoostedH23a1, 10:42 PM 12/10/2002]
Old Dec 10, 2002 | 07:44 PM
noel's Avatar
Default Re: is this where the oil squirters go (BoostedH23a1)
I don't have a clue where they go, but can you give me some info on what all it takes to add the oil squirters? I plan on doing that myself when I finally get my lude and boost that bad boy. BTW do you have GE sleeved block? Did you have to tell them anything about the oil squirters?
Thanks,
Noel
Old Dec 10, 2002 | 10:00 PM
SilverLudeSi's Avatar
New User
Default Re: is this where the oil squirters go (noel)
From what I've heard, oil squirters aren't necessary when running forged pistons. So save yourself the money.
Old Dec 10, 2002 | 10:55 PM
boomslang's Avatar
Default Re: is this where the oil squirters go (SilverLudeSi)
Ditto.
Old Dec 11, 2002 | 04:12 AM
satan_srv's Avatar
Default Re: is this where the oil squirters go (boomslang)
really eh? Well maybe I'll take mine out.....I suppose the oil pressure is better used elsewhere?
Old Dec 11, 2002 | 05:44 AM
flip b18b's Avatar
Default Re: is this where the oil squirters go (satan_srv)
having the oil squirters is a good idea. they will make oil stravation less liekly. but on the other hand i've seen people run with out them. there a good safty percaution though
Old Dec 11, 2002 | 05:58 AM
boomslang's Avatar
Default Re: is this where the oil squirters go (hondafreakc5)
They are present to cool the stock cast pistons. That is it.
Old Dec 11, 2002 | 05:59 AM
satan_srv's Avatar
Well not having the squirters means more oil for the crank right? If it's just for cooling I'm taking them out so my crank doesn't suffer!
[Modified by satan_srv, 10:39 AM 12/11/2002]
Old Dec 11, 2002 | 07:21 AM
willnt it still help though? oil will still flow through there as of right now i think it just isnt shooting up at the piston... right?
Old Dec 11, 2002 | 09:26 AM
2point6's Avatar
If you add the squirters and use the h23 crank, you will have some minor clearance issues to deal with as well. I would add them (IMO) if nothing more than a "safety net", but you will have to get the counter weights "shaved" a bit.
Old Dec 11, 2002 | 09:43 AM
satan_srv's Avatar
Default Re: is this where the oil squirters go (2point6)
Mine were already modifed
How much would these go for?
Old Dec 11, 2002 | 09:47 AM
ehh **** it i guess. i wanna have everything balanced.. how much is that ruffly.
camshafted
Oct 13, 2010 05:19 AM
Doom325
Mar 25, 2005 12:39 PM
