96-98 honda civic alarm install
Old Dec 10, 2002 | 04:42 PM
x00gsr's Avatar
Default 96-98 honda civic alarm install
Need a wiring color guide for a 98 honda civic ex. Planning to install the Dei responder 790.. need help with auto start also...yes it is an auto..
Old Dec 10, 2002 | 07:27 PM
BigWeave's Avatar
Default Re: 96-98 honda civic alarm install (x00gsr)
Hey. I can hook you up. I am an audio installer, and have the same car. Should I post the colors here ? or e-mail them ?
Why cant I post in the classifieds section ?
Old Dec 11, 2002 | 01:27 AM
TurboBumblBee's Avatar
Default Re: 96-98 honda civic alarm install (BigWeave)
cause your a NOOB!! here is a dei wiring guide.. i work for an authorized dealer so i have access to this info..
dkp = drivers kick panel
good luck
12volts white + ignition harness
Starter black/white + ignition harness
Second Starter none
Ignition black/yellow + ignition harness
Second Ignition yellow + ignition harness
Third Ignition none
Accessory white/black + ignition harness
Second Accessory none
Keysense
Power Lock green/white - blue plug dkp
Power Unlock green/orange - blue plug dkp
Lock Motor none non none
Unlock Motor none non none
Parking Lights+ red/black dkp/fuse box
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. green/red - factory alarm plug
Dome Supervision none non none
Trunk/Hatch Pin blue/blk - dkp, harness to rear
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock none non none
Tachometer blue AC test connector
Wait to start
Brake Wire green/white + brake switch
Parking Brake
Horn Trigger gray or blue - column
Old Dec 11, 2002 | 07:13 PM
x00gsr's Avatar
email me them to me..thanks.. xay@bellsouth.net
Old Dec 11, 2002 | 08:55 PM
rjr162's Avatar
just a hint.. in the 96-98 if it's an LX, HX, or EX it's going to have a factory "security" harness behind the radio. You can find alot of the wires you're looking for there (such as the keyless entry options, horn honk, trunk trigger, etc). Plus, when you have it wire, you can just shove the brain straight back into the radio hole.. way back into the dash. Perfect spot for it because you don't see it when you look up under the dash, yet it's a convinent place to get to if you have an aftermarket radio and know it's there.
slikz714
Jul 21, 2007 03:27 PM
choppin_civic
Jun 10, 2006 10:50 PM
truckramrod
Audio / Security / Video
Mar 5, 2006 07:00 PM
b16 matt
Dec 19, 2005 05:13 AM
njandrewg
Mar 9, 2005 12:22 PM
