ls>2.0 sleeving question
Old Dec 10, 2002 | 11:34 AM
itrSteez's Avatar
Default ls>2.0 sleeving question
whats the bore of the sleeves that it takes to get a ls up to close to 2.0 on stock rods, and who would you suggest for sleeves
Old Dec 10, 2002 | 11:52 AM
Jeff C's Avatar
Default Re: ls>2.0 sleeving question (prawjEKt Cx)
84mm bore
Golden Eagle seems pretty reputable.
Old Dec 10, 2002 | 02:48 PM
Kataku2K3's Avatar
Default Re: ls>2.0 sleeving question (Jeff C)
84mm bore
I agree.... GE does some awesome *** work... check them out at... http://www.goldeneaglemfg.com/sleeves.htm
Old Dec 11, 2002 | 02:33 PM
itrSteez's Avatar
Default Re: ls>2.0 sleeving question (JDMspecEG6)
does anybody have a rough estimate of where that price falls with the machine work?
Old Dec 11, 2002 | 04:21 PM
riceboy's Avatar
when you sleeve an LS to 84, coolant jacket volume is comprimised.
Old Dec 11, 2002 | 06:04 PM
Kataku2K3's Avatar
Default Re: ls>2.0 sleeving question (riceboy)
Yes but if you want a ~2.0L motor it's a lot stronger to go with a sleeved LS than a B20... At 84mm bore with the standard GE sleeves cooling isn't going to be a problem.... My friend's GE sleeved B20 to 86mm is still fine... More of a problem may come up if you go with the Godzillas... Latez
Old Dec 12, 2002 | 03:23 AM
Jeff C's Avatar
How is coolant jacket volume on a sleeved LS to 84mm any differnet than a stock b20? How come so many people talk about sleeving an LS then? Would your same statement apply to a sleeved b18 block to 84mm? If not, why? I mean I dont know I dont have a sleeved block.
Old Dec 12, 2002 | 05:54 AM
boomslang's Avatar
How so? The sleeves have the same OD if you run 81mm or 84mm bores.
I have an 85mm bore GE block, it has the same sleeves as someone running 81mm bore.
Old Dec 12, 2002 | 10:07 AM
Kataku2K3's Avatar
Default Re: ls>2.0 sleeving question (boomslang)
Maybe he's talking about the outward flex pins that GE blocks have?? Those don't take up that much space... I dunno what he's talkin about... Peace
Old Dec 12, 2002 | 10:16 AM
blackANESE's Avatar
Leightner and Bush in Canada do a pretty good job too if Golden Eagle
is too pricey for you.
Old Dec 12, 2002 | 03:43 PM
itrSteez's Avatar
Default Re: ls>2.0 sleeving question (blackANESE)
how do i get ahold of them?
xism
Jan 10, 2007 05:47 AM
nvmyb20hatch
Nov 20, 2004 02:01 PM
advance concepts
Jun 30, 2003 02:39 PM
TenaciousC
Nov 14, 2002 02:47 AM
