turbo the D16Z6, or B18C1 swap?
Guest
Posts: n/a
one of my friends has a 94 del Sol Si and he has a B18C1 engine he wants to put in it, all he has is the engine, no tranny, or axles, or ECU, or anything, just the B18C1.... well, there is a guy locally that has a SOHC GReddy turbo kit, it has been passed around a few times, but has never even been put on a car.. my friend could probably pick it up for around $1000. anyways, since he got the engine fairly cheap, i told him he should sell the engine, make some money on it, then buy the turbo and put it on his SOHC. he'd end up cheaper, and i told hime with proper tuning, he should be able to push more than 7psi.... anyways, what are your thoughts on this?
Stick with the swap. A new greddy kit he should be able to buy for $1500 easily. It's not worth buying something used. However the Daily Driver Swap would be nice. Then hook up a Turbo... Just my personal for his situation since he already has the B18C in hand.
I think you should go for the turbo..........and sell me the motor for abouts $800. Ya know how common b18c1s are and all, they dont bring very high resale
Guest
Posts: n/a
Think long and hard about how fast you want to go and how much money you have. Then think long and hard about how long you are going to keep the car...
Those factors will give you a better answer then anyone on this board can.
Guest
Posts: n/a
not my car.... if it was mine, i would swap it, and boost it, but my friend wants to spend as little money as possible, but still be kinda fast, i personally think turbo is the way for him to go
ANd if he sells the B18C1...let me know.....I'll give it a good home......
it's in pieces, you'd have to put it back together
I was wondering about this also, and the turbo just isnt worth the money..
Go with the swap. It lasts longer, and you can turbo it later if you want.
