hestiation to start on cold or hot weather: where can i start?
Old Dec 10, 2002 | 07:24 AM
jdmillusion's Avatar
Default hestiation to start on cold or hot weather: where can i start?
i am rare at posting threads at honda-tech, cause most of the time, i'd just go ahead and do a search or im an h-t friend. and i also have done a search, and found a few things, but need more info than those. this question sounds simple enough to the tech gurus, just as my topic says...
being a tech am, my guess is it's the starter itself. i'm about to clean it up with an electrical degreaser(any thoughts on those?). it could be a few other things as well. any help is appreciated.
JDMi
Old Dec 10, 2002 | 12:36 PM
Perfectionist's Avatar
Default Re: hestiation to start on cold or hot weather: where can i start? (jdmillusion)
What do you mean by hesitation to start? Does the engine refuse to spin, or doesn't it want to fire right away?
Old Dec 10, 2002 | 01:20 PM
Spade's Avatar
Default Re: hestiation to start on cold or hot weather: where can i start? (Perfectionist)
Doesn't want to fire right away.
Old Dec 10, 2002 | 01:30 PM
GZERO's Avatar
Default Re: hestiation to start on cold or hot weather: where can i start? (Spade)
i guess it could be humidity on the conectors, but i'm not sure, you have to be a lil more detailed.
Old Dec 20, 2002 | 06:39 AM
Default Re: hestiation to start on cold or hot weather: where can i start? (GZERO)
my mistake h-t techs. it does turnover. this is one thing i notice. if my car has been running for a long period of time, the second i turn the engine off, then turn it back on, it dies out. thanx there sgt spade. the idea of replacing my fuel filter is the first thing i'm gonna do, right after i get back from leave. any other suggestions?
thanx again techies
Old Dec 20, 2002 | 09:35 PM
Chiovnidca's Avatar
What year and model?
Old Dec 30, 2002 | 06:51 AM
Default Re: hestiation to start on cold or hot weather: where can i start? (Chiovnidca)
96 civic dx
Old Dec 30, 2002 | 07:28 AM
Spade's Avatar
Can you get a hold of a Mulimeter? Test the battery, and then attempt to start the car while testing the battery to rule out the electrical.
Also, have you pulled your plugs to see what they look like?
Old Dec 30, 2002 | 08:26 AM
i'll be replacing the fuel filter this weekend, replacing brake drum shoes, i'll check the charge reading on both the battery and the starter, and pull the plugs out. anything else? appreciate it.
Old Dec 30, 2002 | 09:06 AM
Spade's Avatar
Those are the basic steps to start at.....we will know more after you test the battery and alternater (not starter) and look at your plugs.
How many miles are on the engine? Has the cap and rotor of the distributor ever been replaced? (may have to do that pending on the spark plugs)
Old Dec 30, 2002 | 10:02 AM
will do. bump.
civisedan
Nov 26, 2011 09:33 PM
Narao
14
Oct 7, 2011 07:25 AM
nObOdy65
Oct 12, 2005 11:06 PM
