Where to wire up Secondary Butterflies (on engine)???
I finished up my 2.0L GSR Swap and am finishing up the break in.
But I haven't wired up the Butterfly valve. I know where I need to wire it up on the ECU. But I do not see any plug or connection in the engine bay (on the mainifold). I see that little brase colored hosing on the side of the I.M. that looks like it is connected to the Butterfly valve. But it looks like it is vacum activated (from the vacum line running from it to the mainfold). Where is the hook-up/plug on the engine for the Secondary Butterflies???? Where is the Solenoid?????
Thanks for your help! A picture would be a big help too!!
Thanks alot.... and thanks to everyone who has helped me out so far with this swap!
[Modified by PSU-TEG, 10:33 AM 12/10/2002]
its a little black canister that is held under the I.M. depending on the year of the b18c you either give it a (12v+) switched power source [odb2 engine] or ground it [odb1]. the other wire runs to the same spot on the ecu, i dont remember where.
The other side goes to A3 on the ecu
u2civic1
Jul 14, 2003 04:44 PM
