Question about crank??
Old Dec 10, 2002 | 05:40 AM
91hondacrx's Avatar
Default Question about crank??
If i took a crank out of a honda crx hf motor and put it into a crx dx motor, would i get more power? I know that the compression ratio is higher in the hf but the hf is also dpfi and dx is mpfi. I was just curious, i asked this before and i had no replies so i thought i would ask once again. Any info would be great.
Thanks,
Matt
Old Dec 10, 2002 | 05:45 AM
spun Vtec's Avatar
Default Re: Question about crank?? (91hondacrx)
i would think it would be worse if anything the hf is built for 72? hp wile the dx crank is made for 102 hp not anything to wory about but it wouldnt be any better and about the compression the hf crank wouldnt effect the dx's compression
dpfi and mpfi=
dual point fuel injection
multi point fuel injection
you know this has nothing to do with the crank right??
[Modified by 4gsicivichatch, 2:46 PM 12/10/2002]
[Modified by 4gsicivichatch, 2:47 PM 12/10/2002]
Old Dec 10, 2002 | 06:23 AM
ricodemus's Avatar
you have those backwards anyway. I wouldn't mess with it, but your answer would come in the specs of the two cranks.
Old Dec 10, 2002 | 11:56 AM
91hondacrx's Avatar
Default Re: Question about crank?? (ricodemus)
I am pretty sure it is the crank that increases the compression. I was not sure of the dpfi thing mpfi, i always get the 2 mixed up. The dx motor is for 92 and the hf is for 64, i believe. I figured if you did swap the cranks, you may have to mess with the timing, but i am not sure, i asked my instructor at school, he said he was not sure.
Matt
Old Dec 10, 2002 | 12:21 PM
SEA Hag's Avatar
If your car has a 92 motor, isnt that a d15b7? If thats what you have forget about the HF. What is the difference in stroke on the two cranks anyway?
Old Dec 10, 2002 | 12:26 PM
91hondacrx's Avatar
Default Re: Question about crank?? (SEA Hag)
i am not exactly sure right now but i can check tomorror. the hf motor crank is a like 9:1 compression and the dx is like 8:4:1. Something of that nature, i can get the EXACT specs tomorrow. We have this Mitchell on demand program that has almost any and everything about the car of how to's. pretty cool stuff. Oh yeah, my motor is the d15b2, not b7, 92 horse.
Matt
Old Dec 10, 2002 | 02:03 PM
crxgurlllll's Avatar
its the pistons that control compression.....but also
most if not all 1.5 cranks from 88-2000 are all the same
i know for a fact all 1.6 cranks are the same from 88-00
us31wking
Aug 24, 2014 11:23 AM
craigboostedrex
Apr 6, 2011 07:25 PM
viciousvisionslarry
Dec 7, 2006 09:08 PM
tgreaves
Dec 16, 2003 01:59 PM
