Engine assembly question, JE rings.
Old Dec 10, 2002 | 05:15 AM
Plan B's Avatar
Default Engine assembly question, JE rings.
Okay, now that i've got you in here. I have a question for you guys that have built your own motors.
I just got a set of JE pistons and when I went to file the rings, the top rings were perfect, but the 2nd rings, the iron ones, were gapped at about .018, and the max gap i needed for my application was .0060. I spoke to my supplier and he is going to try to get me another set with the quickness. But has anyone else had this issue also?
I mean i never filed one ring and they were too big, WTF?
Thanks.
Old Dec 10, 2002 | 04:17 PM
vtecrx's Avatar
Default Re: Engine assembly question, JE rings. (Plan B)
have you double checked the diameter of the cylinder? maybe that is too big and the rings are right.
Andy
Old Dec 10, 2002 | 04:19 PM
BoostedH23a1's Avatar
Default Re: Engine assembly question, JE rings. (vtecrx)
in unrelated news. dont forget to stagger the rings..
Old Dec 10, 2002 | 04:40 PM
Plan B's Avatar
that is an excelent observation, but the pistons seem to fit perfectly.
I even took the wax/oil/whatever off the inside of the cylinderwall from the machinist.
I will investigate further, actually this is the 2nd time this has happened with a motor using JE pistons at this machine shop.
Je is sending me another set of rings right now.
Old Dec 10, 2002 | 06:14 PM
earl's Avatar
Thanks.
I've gotten the wrong rings from JE before but .006 seems a little tight for most Honda applications. Am I reading you wrong?
Old Dec 10, 2002 | 06:36 PM
b19coupe's Avatar
Default Re: Engine assembly question, JE rings. (earl)
.006" does seem pretty tight, are you sure about that measurement?
These are the instructions that come with most JE piston/ring kits. Note that it says .006" for each inch of bore.
https://honda-tech.com/zerothread?id=354422
See above thread.
[Modified by b19coupe, 3:38 AM 12/11/2002]
Old Dec 10, 2002 | 06:49 PM
b19coupe's Avatar
What is your bore, and what is your application-N/A, forced inducion, nitrous?
Old Dec 10, 2002 | 07:26 PM
Shawn C's Avatar
In The Garage
Default Re: Engine assembly question, JE rings. (b19coupe)
his application is a 12.5:1 compression b18c1 bored .020", so a 3.209" bore. its gonna stay n/a, but be street driven. i dont know what the hell hes doin right now, so i went ahead and posted this. yeah i think his calculations are actually wrong. thats not like him...... he needs a .0160" gap on the top ring, .0144" gap on the second ring, and a .015" gap on the oil ring. hmmm.....
[Modified by 22lbGS-R, 4:33 AM 12/11/2002]
Old Dec 10, 2002 | 07:33 PM
b19coupe's Avatar
Default Re: Engine assembly question, JE rings. (22lbGS-R)
I would go .016" on the top ring and .012" on the second ring on that setup.
Old Dec 10, 2002 | 07:35 PM
Shawn C's Avatar
In The Garage
his rings still came gapped too much. damn file-fit rings. anybody heard anything about the arias total seal gapless rings??
Old Dec 10, 2002 | 07:40 PM
blackANESE's Avatar
I would not use total seal. Just my personal experience.
MastaFlyMason
Engine Machining & Assembly
Dec 14, 2017 04:08 PM
RACEPAK
Oct 15, 2007 06:00 AM
int3gra
Jul 4, 2002 06:03 AM
int3gra
Jul 3, 2002 04:55 PM
Slick GS-R
May 13, 2002 07:40 AM
