87 crx si sunroof filler piece?
is the panel itself damaged or corroded? if you just want to keep the hole filled (plus lighter) , you can pull the sunroof frame and motor and go to home depot and get a long piece of angled aluminum and cut strips to make brackets which will hold it nicely - i used a silicone sealer to fill the gap around the edge and to get rid of the drain off system
Slowpoke9
Jun 30, 2017 09:50 PM
