what FMU to use?
Old Dec 9, 2002 | 04:29 PM
BoostedB20A's Avatar
Default what FMU to use?
Im tuboing my 90 si lude. Anyone know what FMU I should use? Thanks alot.
Old Dec 9, 2002 | 04:37 PM
Sonny's Avatar
Default Re: what FMU to use? (BoostedB20A)
For stock injectors, use 12:1 and limit yourself to 5-6 psi of boost.
From there, just do the math. As a general rule, for every x% increase in injector size, you decrease the FMU disk by the same x%. Example...30% increase in injector size = 30% decrease in FMU disk. In your case, that'd be an 8:1 disk. That will keep you in the ballpark.
Sonny
Old Dec 9, 2002 | 04:39 PM
SIK IN DA HED's Avatar
New User
Default Re: what FMU to use? (Sonny)
Sonny
sonny is the man. lol
Old Dec 9, 2002 | 04:51 PM
Default Re: what FMU to use? (dlplayboy)
Thanks guys. I will be running RC 550 injectors and a walbro 255 fuel pump. Can I use any FMU with the right disc? Thanks again.
Old Dec 9, 2002 | 06:57 PM
ttt
Old Dec 9, 2002 | 07:09 PM
Sonny's Avatar
You didn't say whether or not you are using a standalone to control those injectors. Since your question was originally about an FMU, I am assuming that you are not using a standalone.
In that case, get Zip's SMC. You do not need an FMU to control 550cc injectors. They deliver plenty of fuel under boost, but they will be way overkill at part throttle and idle. The SMC is a cheap, easy, and works well. You can get one from http://www.diabloautosports.com (it's made by Zip aka ECG Electronics).
Sonny
Old Dec 9, 2002 | 07:20 PM
Wow, you rule. But I have one more question. Will it work over 14psi of boost? I plan on running 17-18psi on the street and 20-22psi at the track. Thanks again for all your help.
Old Dec 10, 2002 | 11:32 AM
bump
Old Dec 10, 2002 | 02:15 PM
TeStUdO's Avatar
youll throw a code somewhere a little past 11lbs.
Old Dec 10, 2002 | 02:23 PM
Mr.DC2TurBo's Avatar
There's no way you will be able to run past 10psi with just a FMU. Now if you ditch the FMU an get a hondata or get a v-afc to controll those 550cc injectors then you might be able to run up to +12 psi without getting a cel. Anything higher you will need to either get a hondata or AEM or other blingbling fuel mangement system. GL
Old Dec 10, 2002 | 02:27 PM
New User
if youre planning on running that much boost... get a Hondata. no questions asked. you cant rely on bandaid fuel setups like the SMC, AFC, or FMU for that much boost.
Old Dec 10, 2002 | 03:18 PM
hondata dose not offer anything for my car. i cant find an ecu anywhere. 1990 prelude si ALB 5 speed
Old Dec 10, 2002 | 03:29 PM
DLB1994's Avatar
get a true standaolone then or even pms
Old Dec 10, 2002 | 03:52 PM
afc or smc i guess
Old Dec 10, 2002 | 06:43 PM
Default Re: what FMU to use? (Dr.TurBo2006)
I may sound dumb, but whats SMC?
Old Dec 11, 2002 | 11:18 AM
so what should I buy?
Old Dec 11, 2002 | 11:26 AM
DLB1994's Avatar
any thing under 10psi smc or afc hack or 12:1 fmu with stock 240cc and inline pump
over 10psi you need a standalone or something like PMS
you can go with something like 440cc and a s-afc ,inline pump with a like a 5:1 rise rate fmu not safe but will work up to about 16psi
or the inline pro setup 255lph intank pump 12:1 rise rate fmu and 440cc and they have seen up to 20psi with this on race gas
Old Dec 11, 2002 | 12:55 PM
autoEXturbo's Avatar
Default Re: what FMU to use? (DLB1994)
This is what i use. Vortech FMU 12:1 disk, 440cc injectors, safc, missing link. 10psi=326hp and 221ft. lbs of torque to the wheels. This is on a gsr motor though. The FMU setup is safe and works great. We'll make over 500hp on it once i get a bigger pump and lines.
Old Dec 11, 2002 | 01:43 PM
b16ahybrid's Avatar
Default Re: what FMU to use? (autoEXturbo)
Just out of curiosity why spend all that money on that when you could spend the same on hondata and have complete control over fuel, and ignition timing?
The idea of runing a smc with 450's ran through my mind for a split second then i thought about ignition timing....it's a pain in the ***, i hate runing retarded timing and losing hp...just me and my thought.....
Old Dec 11, 2002 | 05:32 PM
b18cx's Avatar
Default Re: what FMU to use? (b16ahybrid)
I understand we all need a hondata. I'm sure that at the time most of us would have bought a hondata. But when your starting out and building it as you go ,you do what you can. Missing link-$50, Fmu-$100, inline pump-$100, Intank-$130. Now spread this out and it seems more appealing. Then consider getting the hondata with boost option and the other bells and whistles?????$$$$$$. Then factor in the cost of tuning the hondata or getting a lap top to do it your self????$$$$. <U></U> . Money most don't have. Sometimes its just not feasable. I'm just tired of seeong post stating get a Hondata. Lets just all assume that we all will get one. Just not right now. In the mean time, lets answer the question the best we can.
Old Dec 11, 2002 | 05:55 PM
swrdply400mrelay's Avatar
In your case, get 310cc injectors, AFC, and a Cartech FMU (they're adjustable without need of discs).
Old Dec 11, 2002 | 07:14 PM
Default Re: what FMU to use? (swrdply400mrelay)
Ok heres what I got: t3/t04e, FMIC, msd ignition, walbro 255 in tank pump, RC 550 injectors, delta red top wastegate, bov, gauges, yada yada yada. So what else should I do about fuel? Im dumb, sorry.
Old Dec 12, 2002 | 05:03 AM
Simple, it's not needed. I don't have a standalone, and i'm running right along that guys that do. It wasn't near as expensive as the hondata or any other standalone and it works wonders. Hondata is nice, but i prefer something like the haltech and even the it wouldn't be real streetable. The fmu setup is perfect on the street and at the track.
Old Dec 12, 2002 | 07:17 AM
AFC or a programmable ECU. I hope that isn't the high pressure model fuel pump.
Old Dec 12, 2002 | 07:25 AM
why do you hope its not the high pressure fuel pump? and by AFC, you mean that apex'i thing correct? thanks again.
