anyone have bearing codes for b16a?
Old Dec 9, 2002 | 04:22 PM
theturbocivic's Avatar
Default anyone have bearing codes for b16a?
i have 1st gen b16 and i need the main and rod bearing codes if anyone would help id really appreciate it alot
thanks
Old Dec 9, 2002 | 07:59 PM
brian b's Avatar
New User
Default Re: anyone have bearing codes for b16a? (theturbocivic)
B16A/B17A Rod bearings
13211-P30-003 BLUE
13212-P30-003 BLACK
13213-P30-003 BROWN
13214-P30-003 GREEN
13215-P30-003 YELLOW
13216-P30-003 PINK
13217-P30-003 RED
Main upper bearings (B16A, B18C, B18B, B20)
13321-PR3-004 BLUE
13322-PR3-004 BLACK
13323-PR3-004 BROWN
13324-PR3-004 GREEN
13325-PR3-004 YELLOW
13326-PR3-004 PINK
13327-PR3-004 RED
Main lower bearings (B16A, B18C, B18B, B20)
13341-PR3-004 BLUE
13342-PR3-004 BLACK
13343-PR3-004 BROWN
13344-PR3-004 GREEN
13345-PR3-004 YELLOW
13346-PR3-004 PINK
13347-PR3-004 RED
Main Bearing Set
2.013-2.010 mm 0.0793"-0.0791"
2.010-2.007 mm 0.0791"-0.0790"
2.007-2.004 mm 0.0790"-0.0789"
2.004-2.001 mm 0.0789"-0.0788"
2.001-1.998 mm 0.0788"-0.0787"
1.998-1.995 mm 0.0787"-0.0785"
1.995-1.922 mm 0.0785"-0.0757"
Conrod Bearing Set
1.510-1.507 mm 0.0594"-0.0593"
1.507-1.504 mm 0.0593"-0.0592"
1.504-1.501 mm 0.0592"-0.0591"
1.501-1.498 mm 0.0591"-0.0590"
1.498-1.495 mm 0.0590"-0.0589"
1.495-1.492 mm 0.0589"-0.0587"
1.492-1.489 mm 0.0587"-0.0586"
Old Dec 9, 2002 | 08:10 PM
Shawn C's Avatar
In The Garage
the codes for the rod bearings are printed on the crank and the rods, the codes for the main bearings are printed on the block and the crank. it tells you how to match up the codes in the haynes service manuals
Old Dec 9, 2002 | 08:12 PM
Shawn C's Avatar
In The Garage
Default Re: anyone have bearing codes for b16a? (22lbGS-R)
just kidding. theyre printed above my post, too. just put those together
turbohatch96y7
Mar 9, 2013 03:10 PM
Jcup315
Sep 21, 2006 01:47 PM
hondaapi
Nov 23, 2005 04:29 AM
1.8T_EG
Apr 3, 2003 09:44 PM
pinkcivic
Nov 19, 2001 03:17 AM
