Crime Stoppers(remote start) Alarm *NEW*
Old Dec 9, 2002 | 12:24 PM
BronxAccord's Avatar
Default Crime Stoppers(remote start) Alarm *NEW*
Im selling a crime stoppers alarm thats brand new in box.Bought it to put in my 4th gen accord but i ended up finding out that putting remote start on a stick is illegal here in NY.So im selling it for 1/2 the price i bought it for shipped,which is $90Firm. i got this quote below directly from the crimestopper website.
this idem is brand new in factory packaging SECURITY FEATURES Two Ergonomic, 4-Button, Multi-Channel Transmitters with the SecureGlow™ Illumination 6 Tone 125dB Siren Dedicated Arm and Lock, Disarm and Unlock, Remote Start & Auxiliary Feature Buttons Reduce Confusion and Simplify Transmitter Use Transmits on 433 MHz Frequency for Less RF Interference and Greater Reliability Electronic "Dual Stage" Shock Protection (Plug-In Design) Dynamic Code Anti-Code Grabbing Protection Code Learning Receiver Audible & Visual Arm/Disarm with Intrusion Alert Alarm Pre-Warning Signal Multi-Zone Trigger Protection Defective Zone Bypass with Warning Chirps Remote Panic Starter-Disable Protection with On-Board Relay On-Board Flashing Light Relay Protected Valet/Programming Switch (PlugIn Design) LED Status Indicator (Plug-In Design) Dedicated Vehicle or Air Horn Pulsing Output with Trigger on Doors Passive or Active Arming (Programmable) Active Re-Arming Mode (Programmable) Door Lock Pulse Time (Programmable 1 or 3 Sec.) Power Down Monitoring with Novram Circuit -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- REMOTE START FEATURES Selectable Engine Speed Sensing, Tach or "Smart" Tachless Operation Four On-Board Relays for Easy Installation Programmable Run Time of 10, 20 or 40 Minutes Anti-Grind Feature. Prevents Accidental Key Grinding Factory Alarm Disarm. Disables Factory Alarm Before Remote Starting and when Unlocking with Keyless Entry Gas or Diesel Engine Operation Hood Open Safety Circuit. The Unit will not Remote Start if Hood is Open Brake Pedal Reset Negative Outputs for Additional Ignition or Accessory Relays Three Remote Start Attempts -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- CONVENIENCE AND VALUE-ADDED FEATURES Remote Keyless Entry (Controls Power Door Locks) Separate Driver/Passenger Door Unlock Control Remote Auxiliary Output for Optional Power Trunk Release, Power Window Control Module, Etc. Silent Arm and Disarm Valet Service/Valet Park Modes Transmitter Low Battery Indicator Dome Light Illumination (Requires Relay) Programmable Parking Light Illumination on Disarm (Car Finder) Multi-Car Remote Control Capability Easy Programming Double Unlock Pulse. Programmable Feature for Factory Alarm Interfacing Qualifies for Insurance Discount Transferable Limited Lifetime Warranty Crimestopper Security Products, Inc
vingavina
Honda Civic (2006 - 2015)
Mar 25, 2008 12:35 PM
killakoupe
Oct 29, 2006 08:21 PM
