What parts Do i need for a tranny swap?
Old Dec 9, 2002 | 10:31 AM
i_krayzie_i's Avatar
Default What parts Do i need for a tranny swap?
What parts are needed besides the obvious (tranny)(ecu) to convert a 2001 prelude to a manual from auto???? I have a shop that will do it as long as i provide the parts. So far ive found a tranny i just need to find other parts so if anyone knows what i need or has been threw this process let me know or even has anything for sell that i might need thanks.
Old Dec 9, 2002 | 11:17 AM
satan_srv's Avatar
Default Re: What parts Do i need for a tranny swap? (i_krayzie_i)
SEARCH.
https://honda-tech.com/zerothread?id=350605
Read what aklucsarits has to say.
In addition to the tranny itself, the pedal assembly, and shift linkage, you also need:
Manual Tranny Mount
Manual Starter
Manual ECU
Clutch
Flywheel
Axles
Clutch Master Cylinder
Clutch Slave Cylinder
Clutch Damper Assembly
Hydraulic Lines
Manual Gauge Cluster (optional)
Shift Boot
Shift ****
Honda Manual Tranny Fluid
Andrew
[Modified by satan_srv, 3:17 PM 12/9/2002]
preludejayes
Aug 26, 2006 08:20 PM
kdizzle09
Feb 1, 2006 05:58 PM
kikkoboyie
Apr 27, 2002 06:25 PM
