idle problems with bored TB
Old Dec 8, 2002 | 11:08 PM
pinota's Avatar
Default idle problems with bored TB
Hello,
I got my TB machined 3 months ago, it worked ok in my 98 ITR.
Yesterday iīve installed it on my friend 99 ITR and the idle was very irregular.
We could adjust the TPS only to .415- .420 max. Wy canīt we just raise it to .450 ???
The part numbers on the sensor are the same.
Thanks,
Pinota
Old Dec 9, 2002 | 12:57 AM
Rhetoric's Avatar
Default Re: idle problems with bored TB (pinota)
I have a machined itr tb. The idle is fine, about 800-850.
I did previously have a bbk 70mm and I had a lot of fluctuation between 900-1500rpm.
Old Dec 9, 2002 | 05:18 AM
Dropspeed's Avatar
Default Re: idle problems with bored TB (Rhetoric)
There is an adjustment screw on the upper left side of the ITR throttle body that is covered with paint. Remove the paint and you can make adjustments that wil help with the idle.
Mattj
Old Dec 9, 2002 | 08:33 AM
Euro98ITR's Avatar
Hello,
Thanks,
Pinota
When you say machined what exactly did you do to it ? If possible a pic please.
Old Dec 9, 2002 | 08:55 AM
sil's Avatar
sil
Default Re: idle problems with bored TB (Dropspeed)
when i put my bored out tb in.. it took a lot of tweaking of the TPS and IAS.. also don't forget to reset ecu (well i'm not sure if this helps but i had to because i kept getting a cel)
CHANCELLOR12
Feb 6, 2016 03:46 AM
james007
Apr 30, 2010 04:26 PM
Cleft_Asunder
20
Feb 17, 2009 08:37 AM
eskerley
13
Apr 16, 2008 02:59 PM
