need advice on tranny remounting
Old Dec 8, 2002 | 11:04 PM
spladam02's Avatar
Default need advice on tranny remounting
need some advice on getting this damn tranny remounted i cant get it lined up. first project ive done on an engine and i had to drop the tranny (what was i thinkin) its a BEAR and 25 baby bears
dropped tranny to replace clutch, most of that ran pretty smooth but now i could really use some advice on gettin it back on
Old Dec 9, 2002 | 02:54 AM
tnbigdawg's Avatar
Default Re: need advice on tranny remounting (spladam02)
while you are mounting the tranny, try rotating it a little bit back and forth.
Old Dec 9, 2002 | 04:37 AM
Ricky Rojales's Avatar
If everything is lined up properly it should go on without a hiccup as you tighten down the bolts. If not, then it's not lined up. It's that simple.
Old Dec 9, 2002 | 06:01 AM
1bad-eg's Avatar
Default Re: need advice on tranny remounting (tnbigdawg)
Yeah, sometimes you have to pull the tranny back out, spin the shaft a little and then try again. Sometimes it works and sometimes it doesn't.
Old Dec 9, 2002 | 06:05 AM
b19coupe's Avatar
Did you use a clutch alignment tool? If the clutch is not lined up properly, you can fight that tranny forever and not get it in. Put a very light coating of multi-purpose grease on the input shaft, it will slide in easier.
OBDII Integra
Sep 11, 2009 08:56 PM
ftrms
Mar 5, 2009 06:23 AM
vtecn8ive
23
Apr 23, 2006 06:59 PM
spladam02
Dec 9, 2002 04:11 AM
Lei Siew Long
Aug 16, 2001 02:58 AM
