Would a b18 affect my turning ability at all?
Old Dec 8, 2002 | 10:52 PM
Crxer's Avatar
Default Would a b18 affect my turning ability at all?
im thinking about getting a b16 or a b18. i need to do the auto to manual swap so im looking for a full swap. anyone with a b18 in their crx notice a difference in handling? I drive through alot of twistys and i already got the full suspension and if the b18 is going to screw my handling up im just going b16.....
Old Dec 9, 2002 | 05:03 AM
Superhatch's Avatar
Default Re: Would a b18 affect my turning ability at all? (Crxer)
The difference between the weight of the b16 vs. b18 wont be noticable. I have a b18b swap in my 90 ef, and I didnt notice a huge handling difference.
-Jake
Old Dec 9, 2002 | 06:25 AM
Flexmyrex's Avatar
Default Re: Would a b18 affect my turning ability at all? (SuperHatch)
my ef still handles the same
Old Dec 9, 2002 | 11:29 AM
Crxer's Avatar
Default Re: Would a b18 affect my turning ability at all? (flexmyREX)
thanks guys i guess im going with the ls then are there any other problems with swapping an ls into my rex? like clearance issues? i hear from some people that the hood won't clear and you have to cut it, or you have to modify the crossmember... does it matter on what mount kit you have also?
[Modified by Crxer, 12:31 PM 12/9/2002]
Old Dec 9, 2002 | 12:31 PM
REX VT's Avatar
You may encounter slightly more understeering when you turn in but it is no big deal and can be compensated by a inbound/rebound adj. suspension kit. But you don't need it. I drove a B18c6 SiR and I think it rules. Only the B20 makes the understeer worse and needs more attention. See the picture for the clearance of a B20 in a ZC ..
Old Dec 9, 2002 | 12:44 PM
xtrafastcivic's Avatar
Default Re: Would a b18 affect my turning ability at all? (REX VT)
b20 weighs about the same as a b18....
Old Dec 9, 2002 | 01:30 PM
REX VT's Avatar
Default Re: Would a b18 affect my turning ability at all? (XtraFastCRX)
And a B18 weights about thesame as a B16
Old Dec 9, 2002 | 01:43 PM
Crxer's Avatar
how much does the inbound/rebound kit cost and what exactly does it do?
Old Dec 10, 2002 | 12:31 AM
REX VT's Avatar
Default Re: Would a b18 affect my turning ability at all? (efzero.com)
plus the fact races are won on the straightaway not the turns
Nope they are won by superior brakes before and superior handling through the corner.. I guess an experienced driver also helps.. Ok these are probably not important in oval racing but I'm talking about real tracks
Old Dec 11, 2002 | 10:33 AM
CdTriX's Avatar
that's the most wierdest racing mentality i've ever heard...
i doubt that applies for lets say nascar or indy or even speedvision touring car
since all cars have simular hp figures and weight:hp ratios that accelerating in a straight would not gain you THAT much ground... and passing is mostly done on corners because a skilled driver can shave time off the corner..
isn't track racing about the ability to keep maximum speed around corners and minimize braking time?
Old Dec 11, 2002 | 10:42 AM
FourthGenHatch's Avatar
Default Re: Would a b18 affect my turning ability at all? (CdTriX)
Well in wheel to wheel racing I'm going to say most cars do the passing on the straights, not the turns since it's hard and risky. So he is sort of right in that sense, if thats what that guy meant.
Old Dec 11, 2002 | 12:06 PM
ji1178ob's Avatar
i think you will feel a diffenrence if it was a H22
Old Dec 11, 2002 | 12:11 PM
Crxer's Avatar
Default Re: Would a b18 affect my turning ability at all? (ji1178ob)
well i like to drive the twisty mountain and cornering is very important to me. my d15 POS does not get me up the hill so i was just wondering if i'd be ok with the b18. driving in a straight line does not entertain me.......
ghettoda9
Mar 8, 2012 05:12 AM
jorgejam2001
Sep 20, 2010 07:21 PM
!!miguel!!
12
Apr 19, 2010 09:14 PM
stratedrm
Feb 7, 2010 12:44 AM
