Is my Differential shot?? Help!
Old Dec 8, 2002 | 10:30 PM
95 GSR B20VTEC's Avatar
Default Is my Differential shot?? Help!
Hey.... right now im havin a big problem.... I recently replaced the gears in my tranny, and just the other night i was goin up a street quick in 1st and shifted to 2nd and got some really big wheel hop. And after that.. there was this grinding noise... its not constant its in bursts, And they get closer together as i ACCELERATE or pick up speed, you can hear it in neutral but it just sounds like something bouncing around, its only when its in gear or im accelerating.... im thinking it might be the Differential which i really hope it isnt.... considering i just paid a decent amount to have the tranny almost totally rebuilt... is there anythign else it could be ? if so what can i do to check ?
Old Dec 9, 2002 | 02:56 AM
tnbigdawg's Avatar
Default Re: Is my Differential shot?? Help! (95 GSR B20VTEC)
probably the gears that you just put in went bad, or the install was bad.
Old Dec 9, 2002 | 04:33 AM
Ricky Rojales's Avatar
Sounds like a bad install. I'd open it back up and recheck the work done.
Old Dec 9, 2002 | 04:40 AM
1bad-eg's Avatar
Default Re: Is my Differential shot?? Help! (Ralphie)
open it up and check EVERYTHING. A friend of mine had the same problem, the faster he went the more the noise happened. We took the tranny apart and found the ring gear on the diff was missing some teeth, and that wiped out the countershaft.
Old Dec 9, 2002 | 08:02 PM
Default Re: Is my Differential shot?? Help! (1bad-eg)
Hmmm... alright..... do you think if i caught it in time that there wont be much damage done?
Old Dec 9, 2002 | 08:29 PM
Shawn C's Avatar
In The Garage
yeah my best friend had the same prob. we pulled out his spoon tranny plug and there was a huge chunk of metal stuck to it. his diff was gone, and now hes buildin the ***** out of it. id quit drivin it and take it back apart.
manchildteggy
Dec 13, 2010 08:13 AM
EG-evokilla
Transmission & Drivetrain
Feb 26, 2009 09:06 AM
88crxdxfastwhip
Mar 16, 2007 10:40 PM
SI_you_later
Honda Civic (2006 - 2015)
20
Dec 24, 2006 08:56 PM
mr_nemesis2003
Oct 26, 2006 11:43 AM
