Question: How to remove U pipe and Removing Resinator box
jack up right side of the car
remove some of the lining
there should be two screws holding the box in if i remember correctly.
just yank it out
just yank it out
or to make it really easy take off your front bumper first. should be able to figure it out from there
there should be two screws holding the box in if i remember correctly...[qoute]
on mine there were three(one hidden grrr).no need to remove bumper just get under it with a racthet and extension.
removing bumper = much much easier. you can use the tool with more ease and actually see the hidden screws if you tried to do it w/o taking off the bumper
can you tell me how to remove front bumber then?
sorry i dont wanna mess up and un screw other bolts.
thank you
btw anybody have picture?
thank you
heres some pics
there are 7 of those you have to remove....and one screw on each side of the fender where my finger is pointing...thats all you have to remove
Remove the bumper if you can, otherwise you have to pull/squeeze it through the lining and bumper. I did it without removing the bumper and wish I did. But the actual process of removing the resonator is easy, just locate the 2 or three screws and pull on it.
hondamonkey
22
Apr 19, 2006 09:49 AM
