who can post 90-91 wiring diagram for ECU wiring with B5 and B14 pins
Old Dec 8, 2002 | 09:13 PM
Camshaft's Avatar
Default who can post 90-91 wiring diagram for ECU wiring with B5 and B14 pins
Old Dec 8, 2002 | 10:01 PM
USDM 4G VTEC's Avatar
Default Re: who can post 90-91 wiring diagram for ECU wiring with B5 and B14 pins (Camshaft)
what do u want to know???
what do the pins go to ?? or are u doing a DPFI to MPFI swap and u see cables there
if u swapin Fi those cables arent nuttin to worry about...
or u just swaped it and want to know waht they do??
also exactly what kind ecu u want t know that about... PM6 (Si) or PM(9std) or PM8 DX, or what?
Old Dec 9, 2002 | 03:59 AM
Camshaft's Avatar
Default Re: who can post 90-91 wiring diagram for ECU wiring with B5 and B14 pins (JDM EF9)
making a obd0 to obd1 adapter harness
Running across some conflicting info between my shop key diagram and maybe it looks like helms.
I don't have helms so I'm really intersted in getting a pic of it
thanks
Cam
Old Dec 9, 2002 | 07:51 AM
k if u only wanted those 2 then here we go
as in a 1988 CRX Si 1.6L SOHC D16A6 MPFI diagram taken from All Data it goes as follows...
B5 - wht/yel goes to the alternator
B14 - blu2 goes also to the alternator
i checked my D15B1 1990 1.5L All data diagram and its the same....
another info says that the B5 its the alternator control... B14 just says plain alternator....
since u told me u doing a OBDO to OBDI heres where those 2 goes.... on a 5G the wht/yel goes to ECU pin A16
the blu goes to ECU pin D9
means
B5 to A16
B14 to D9
hope i helped,...
Old Dec 9, 2002 | 09:24 PM
Camshaft's Avatar
Ok I am going crazy
Alldata and Shop key say
obd0
B5 is alt RF signal
B14 alt output
OBD1
D9 alt FR signal
A16 is output signal
which means ( this is what people are saying)
B5 is alt RF signal to A16 is output signal
B14 alt output to D9 alt FR signal
You tell me why does that look WRONG ?
[Modified by Camshaft, 10:46 PM 12/9/2002]
[Modified by Camshaft, 11:03 PM 12/9/2002]
h23vtec_dc2
Honda S2000
May 16, 2011 08:12 AM
emrekin
Oct 31, 2007 12:53 PM
